Oops. A double negative slipped through editing. I meant to say:
"Perhaps it is prudent to create a system that is independent of the depth
of buffering provided by the communication infrastructure."
> -----Original Message-----
> From: Jeff Hill [mailto:[email protected]]
> Sent: Monday, January 08, 2007 12:36 PM
> To: 'Kurt Biery'; [email protected]
> Subject: RE: soft IOC string and array records
> Hello Kurt,
> With CA publish and subscribe we have a consumer producer situation. So if
> the producer (the IOC) produces subscription updates at a sustained rate
> that is higher than the rate at which the consumer (the client side
> application) consumes them then we would need an infinite amount of memory
> to save all of those updates in the server hoping that the client will
> eventually consume at a higher rate. Of course, using an infinite amount
> of
> memory could have a quite negative impact on the health of the IOC so we
> implement some amount of buffering for bursts but choose to discard some
> intermediate updates in situations where the buffer quota has been
> exceeded.
> We of course ensure that a responsive client receives the most recent
> update. There are actually five places where buffering can occur: there is
> buffering in the event queue between records and the server, in the
> server's
> protocol dispatch buffer, in the server's TCP socket, in the client
> library's TCP socket, and in the client library's protocol dispatch
buffer.
> It's also true that the situation is subtly different for array and string
> data types. For those types there is currently no buffering between the
> record and the server. The implication is that if a higher priority record
> processing thread calls db_post_events (if it posts a subscription update)
> twice for these data types without giving up the CPU to the lower priority
> server thread then an intermediate update will be discarded.
> However, when one considers that when designing a reliable distributed
> system we must always assume that client consumption rates might be less
> than server production rates given the many loading variables in a system
> maintained over a number of years on evolving hardware, and the bursty
> nature of systems based on asynchronous network messages, then perhaps it
> is
> prudent to not create a system that is independent of the depth of
> buffering
> Jeff
> > From: Kurt Biery [mailto:[email protected]]
> > Sent: Friday, January 05, 2007 1:06 PM
> > To: [email protected]
> > Subject: soft IOC string and array records
> > At Fermilab, several of us are working on the data acquisition for NOvA,
> > a future neutrino experiment. We would like to use process variables in
> > soft IOCs to pass string messages between processes in the system, and
> > we are trying to understand the best way to accomplish this.
> > With EPICS Base R3.14.8.2, we have experimented with string and waveform
> > records and have noticed that messages are not always delivered to
> > monitor processes when the messages are quickly written to the PV. I'll
> > include some of the details of our tests below, but the central issue
> > seems to be illustrated by the following snippet of code from
> > db_post_single_event_private in dbEvent.c:
> > * if we have an event on the queue and we are
> > * not saving the current value (because this is a
> > * string or an array) then ignore duplicate
> > * events (saving them without the current value
> > * serves no purpose)
> > if (!event->valque && event->npend>0u) {
> > UNLOCKEVQUE(ev_que)
> > return;
> > I don't understand all of the ramifications of this code comment, but it
> > certainly sounds like fast updates to string and array records are not
> > all expected to be delivered. So, the question becomes: if we want
> > updates to a string or waveform record (or something similar) to
> > *always* be delivered to monitors, what are our options? We have
> > casually used CA servers when first learning EPICS, but have not yet
> > investigated whether they have this same feature. Are CA servers an
> > option? Or are there established ways to select the delivery of all
> > updates in a soft IOC?
> > The tests that we ran used a soft IOC created with 'makeBaseApp.pl -t
> > ioc' and database records like the following:
> > record(stringout, "test1/sampleString") {
> > field(DTYP, "Soft Channel")
> > record(waveform,"test1/sampleWaveform") {
> > field(DTYP,"Soft Channel")
> > field(NELM,"32")
> > field(FTVL,"UCHAR")
> > To update the PV value at a reasonably high rate, we simply made a copy
> > of caput.c and added a loop around the writing of the data as shown
> > below (the modification of the first character in the sbuf/pbuf array
> > allowed us to check for missing or duplicate records when observing the
> > updates with a camonitor client):
> > for (idx = 0; idx < 100; idx++) {
> > sprintf(sbuf[0], "%d", idx);
> > result = ca_array_put (dbrType, count, pvs[0].chid, pbuf);
> > result = ca_pend_io(caTimeout);
> > if (result == ECA_TIMEOUT) {
> > fprintf(stderr, "Write operation timed out: Data was not
> > written.\n");
> > return 1;
> > For the waveform record test, we started the soft IOC, ran 'camonitor
> > test1/sampleWaveform', and then ran the modified caput several times
> > with 'caput -a test1/sampleWaveform 5 2 4 6 8 10'. Some of the times
> > that we ran caput, we saw all 100 messages arrive at the camonitor.
> > Other times, only one or two of them did.
> > Thanks in advance for any help that folks can provide with this,
> > Kurt Biery
- RE: soft IOC string and array records Jeff Hill
Re: caRepeater must run before casr Eric Norum
Control / Programming / Scientific Support jobs at the Synchrotron Chris Glover
<2007>
synApps version 5.2 release Tim Mooney
<2007>
