1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: 3.13.6 daylight-savings follies
To: <[email protected]>
Cc: "Laznovsky, Michael" <[email protected]>
Date: Sun, 4 Mar 2007 23:24:55 -0800
Hi- we have a number of hard IOCs running 3.13.6 on vxWorks, and
are wondering how best to approach the upcoming unusual time change.
Staring at the code reveals the following:
EPICS_TIMEZONE is not used in 3.13.6.
TS_MIN_WEST is initialized at compile time to 7*60=420 (US MST; ie.
Chicago/FNAL), and then set to EPICS_TS_MIN_WEST at run time, if that's
defined.  Used by UTC<->local-time conversion routines in tsSubr.c,
and thus also by things like timestampRecord.c (local "timestamp" DB
records).
TIMEZONE is set in base/src/db/drvTS.c but not referenced anywhere
else.  If not already defined at iocInit(), it gets set to
"UTC::<EPICS_TS_MIN_WEST>:040102:100102" (hard-coded).  Appears not
to be used for anything after that... perhaps by vxWorks?  It does
show up in "strings vxWorks" output.
As mentioned in http://www.aps.anl.gov/epics/tech-talk/2007/msg00063.php,
there's no way to prevent the UTC<->local conversion functions from using
the TS_DST_* #defines to add or subtract an hour on the OLD switch dates
in April and October without modifying the code and recompiling base.
So, one option is to reboot on March 11 with TS_MIN_WEST set to "420"
(one time zone over), and then again on April 1st with the old normal
"480" value.  Seems clumsy at best; what are other sites doing?
We need local time on IOC to be correct for timestamp records and the
like; CA clients should be OK since that uses UTC... right?
Mike
Re: 3.13.6 daylight-savings follies Andrew Johnson
Prev: Re: EDM Related Displays Kay-Uwe Kasemir
Next: RE: Serial port access and loging services for IOCs? Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: 3.13.6 daylight-savings follies Andrew Johnson
