1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: EDM Related Displays
To: Robert Emery <[email protected]>
Cc: [email protected]
Date: Fri, 02 Mar 2007 16:10:22 -0500
On Mar 2, 2007, at 15:51 , Robert Emery wrote:
I am using edm to set up operator displays. There are instances where I
would like to open an edm display using a related display button and at
the same time have another edm display (not the one with the related
display button in it) close.
For example, I have a main menu display along the left of the screen and
a beamline display along the bottom. I would use related display
buttons in the main menu display to call up different beamline
displays. If a new beamline related display was selected from the main
menu, I would like it to open and I would like the existing beamline
display (that had previously been opened from the main menu) to close.
Any ideas?
Hi:
I don't think you can close another display via a related button.
But for what you want to do, this might work:
On one big display, you have a row of buttons on the top
or along the left to select a sub display,
then a big "embedded display" area using the rest of that
display.
So that "embedded window" shows your related screen within
the original screen.
The buttons can select which one.
Detail:
The embedded window gets configured to display
one of a list of related displays within its window
based on the value of a PV.
The row of buttons of course writes 0, 1, 2, ... to that
selector PV.
The added trick: For that selector PV, you don't use a PV
on an IOC, because that would mean that every instance of that
screen would show the same embedded sub-display.
Instead, you use a local EDM PV, local to your display instance.
Syntax for that PV:
\LOC\$(!W)MySubSelector=i:0
The idea behind this mad looking PV:
\LOC\ means local, not ChannelAccess
$(!W) gets replaced by the window ID,
so this creates a unique PV
=i:0 creates an integer, initialized with 0
The message buttons use the same "\LOC\$(!W)MySubSelector=i:0"
and write 0, 1, 2, 3, ....
I always get confused about the "i:0":
Whichever widget happens to get initialized first will create
the integer PV with value 0.
On subsequent use, the "=i:0" is really ignored.
EDM Related Displays Robert Emery
Prev: Re: EDM Related Displays Emmanuel Mayssat
Next: 3.13.6 daylight-savings follies Laznovsky, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
