1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Daylight savings time
To: Eric Norum <[email protected]>
Cc: tech-talk tech-talk <[email protected]>
Date: Tue, 13 Mar 2007 11:17:14 -0500
Eric Norum wrote:
Since we're on the topic of time, I'd like to propose the following change to the IOC shell. This is in the handler function for the epicsEnvSet command.
     epicsEnvSet (name, value);
+    if (strcmp(name, "TZ") == 0) {
+        extern void tzset(void);
+        tzset();
This will ensure that changes to the TZ environment variable (in an st.cmd file, for example) actually have an effect.
That change is not portable; according to my reference manual vxWorks doesn't have a tzset() routine, and I have similar doubts about WIN32. Maybe the correct solution would be to register an OS-specific command that can set the IOC's timezone data?
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
Re: Daylight savings time Eric Norum
Daylight savings time Thompson, David H.
Re: Daylight savings time Lawrence T. Hoff
Re: Daylight savings time Andrew Johnson
Prev: Re: Daylight savings time Eric Norum
Next: Re: Daylight savings time Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
