Ernest,
What we do at DLS (and what I used to do in Hawaii) is to install boot
scripts in <TOP>/bin/<target arch>.
We preprocess the boot scripts (i.e. the *.cmd files) to do target
architecture specific macro substitution (to form *.boot files). So
instead of the cdCommands and envPaths files we do it all through macro
substitution in the st.cmd file. For example, the makeBaseApp.pl st.cmd
file for the application <fred> looks like this:
#!$(INSTALL)/bin/$(ARCH)/fred
## You may have to change fred to something else
## everywhere it appears in this file
cd "$(INSTALL)"
# Load binaries on architectures that need to do so.
# VXWORKS_ONLY, LINUX_ONLY and RTEMS_ONLY are macros that resolve
# to a comment symbol on architectures that are not the current
# build architecture, so they can be used liberally to do architecture
# specific things. Alternatively, you can include an architecture
# specific command file.
$(VXWORKS_ONLY)ld < bin/$(ARCH)/fred.munch
## This drvTS initializer is needed if the IOC has a hardware event
system
#TSinit
dbLoadDatabase("dbd/fred.dbd")
fred_registerRecordDeviceDriver(pdbbase)
## Load record instances
#dbLoadRecords("db/<filename>.db","<List of macros, e.g. user=xxx>")
## Set this to see messages from mySub
#mySubDebug 1
iocInit()
## Start any sequence programs
#seq sncExample,"user=xxx"
Note that, once built, this runs on all VxWorks architectures and Linux
- I don't know about RTEMS, since we don't have it here (but I must
admit that the $(VXWORKS_ONLY) macro is a bit kludgy and would welcome
better suggestions). The macro substitution idea isn't mine, it dates
from an ages old LANL application environment (but I think that used to
use colons to separate the macros - it was before we all decided to use
Note we do this all via site wide CONFIG.Dls and RULES.Dls files and so
this gets rid of another pet hate of mine - the special inclusion of
RULES.ioc file in startup directories so the build rules are different -
all Makefiles just include one RULES file and so have access to the same
set of make rules.
I can send our special RULES.Dls and CONFIG.Dls to you if you want. We
also find we need another installation directory called (we call is
data), and a DATA make target for architecture independent
configurations (such as edm screens, protocol files, archiver
configuration, alarm configuration, motor controller programs etc).
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
> -----Original Message-----
> From: Ernest L. Williams Jr. [mailto:[email protected]]
> Sent: 07 May 2007 22:56
> To: [email protected]
> Cc: [email protected]; [email protected]
> Subject: INSTALLING IOC Applications
> Hi,
> In order to take full advantage of "INSTALL_LOCATION_APP", we need to
> install the products from iocBoot as well. Has anyone else
> address this
> issue at their site?
> Proposal:
> Before doing a make:
> <TOP>
> --configure
> -- <yourAppName>App
> -- <iocBoot>
> After doing a make:
> <TOP>
> --configure
> -- <yourAppName>App
> -- <iocBoot>
> -- bin
> -- db
> -- dbd
> -- include
> -- lib
> -- iocStartup
> -- ioc<yourIOCName>
> -- st.cmd
> -- cdCommands
> -- envPath
> Notice, now that there is a new product directory called "iocStartup"
> Of course, now the RULE could be changed to move "iocStartup"
> along with
> bin, db, dbd, include, lib to the desired installation tree.
> Looks like clean and uninstall will work just fine as well.
> Thanks,
> Ernest
INSTALLING IOC Applications Ernest L. Williams Jr.
EPICS Meeting presentations - online Matthias Clausen
<2007>
<2007>
