I'm trying to configure and use the CAJ library, since I can't be sure what kind of machine the application will be used on. It can almost be guaranteed that whatever machine it is, it won't have EPICS on it, for sure. Hi, David. CAJ requires JCA. Have you built JCA yet? When I built CAJ, I had to edit the build.xml file to tell it where my JCA library was. In the part that looks like this <path id="build.classpath"> <pathelement location="../jca-2.3.0.jar"/> </path> I replaced "../jca-2.3.0.jar" with the path to my JCA jar file. Then I was able to do $ ant clean $ ant The caj.jar file is created at "target/caj.jar". -lewis -- J. Lewis Muir Software Engineer CARS/IMCA-CAT
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
