I've been trying to get a Lakeshore 340 temperature controller working via a Agilent E5810A Ethernet to GPIB gateway. I can run a soft IOC and communicate successfully using an AsynRecord, writing to the AOUT field and reading the result back from the AINP field. However, I would like to use the 340 via streams. My protocol file looks like: Terminator = CR LF; ReplyTimeout = 1000; getID { out "*IDN?"; in "%s"; } And the record tied to this, is: record(stringin, "$(P):ID") { field(DTYP, "stream") field(INP, "@ls340.proto getID L0 12") } If I process the record, then the IOC prints: ************************ epics> 2007/05/11 15:55:45.125 L0 addr 12 queueRequest priority 0 not lockHolder 2007/05/11 15:55:45.125 L0 schedule queueRequest timeout 2007/05/11 15:55:45.125 L0 callback 2007/05/11 15:55:45.125 L0 addr 12 queueRequest priority 0 not lockHolder 2007/05/11 15:55:45.125 L0 schedule queueRequest timeout 2007/05/11 15:55:45.125 L0 callback 2007/05/11 15:55:45.125 L0 12 vxiWrite numchars 5 2007/05/11 15:55:45.128 L0 12 vxiWrite *IDN? *IDN? 2a 49 44 4e 3f 2007/05/11 15:55:45.128 L0 addr 12 queueRequest priority 0 from lockHolder 2007/05/11 15:55:45.128 L0 schedule queueRequest timeout 2007/05/11 15:55:45.128 L0 callback 2007/05/11 15:55:45.128 L0 vxiSetEos 0 2007/05/11 15:55:45.140 L0 12 vxiRead L L 4c 2007/05/11 15:55:45.140 BL16I-EA-LS340-01:ID: asynOverflow: 2007/05/11 15:55:45.140 BL16I-EA-LS340-01:ID: I/O error from device 2007/05/11 15:55:45.140 BL16I-EA-LS340-01:ID: Protocol aborted ************************* This is with all asyn tracing turned on. The equivalent printout for the AsynRecord, is: **************************** 2007/05/11 15:57:53.682 L0 addr 12 queueRequest priority 0 not lockHolder 2007/05/11 15:57:53.682 L0 schedule queueRequest timeout 2007/05/11 15:57:53.682 L0 callback 2007/05/11 15:57:53.682 mp49:asyn:Record: asynCallbackProcess, state=3 2007/05/11 15:57:53.683 mp49:asyn:Record flush 2007/05/11 15:57:53.683 L0 12 vxiWrite numchars 5 2007/05/11 15:57:53.685 L0 12 vxiWrite *IDN? *IDN? 2a 49 44 4e 3f 2007/05/11 15:57:53.685 mp49:asyn:Record: nwrite=5, status=0, nawt=5 *IDN? *IDN? 2a 49 44 4e 3f 2007/05/11 15:57:53.741 L0 12 vxiRead LSCI,MODEL340,342162,042304 LSCI,MODEL340,342162,042304\r\n 4c 53 43 49 2c 4d 4f 44 45 4c 33 34 30 2c 33 34 32 31 36 32 2c 30 34 32 33 30 34 0d 0a 2007/05/11 15:57:53.741 mp49:asyn:Record: inlen=40, status=0, ninp=29 LSCI,MODEL340,342162,042304 LSCI,MODEL340,342162,042304\r\n 4c 53 43 49 2c 4d 4f 44 45 4c 33 34 30 2c 33 34 32 31 36 32 2c 30 34 32 33 30 34 0d 0a 2007/05/11 15:57:53.741 mp49:asyn:Record: inlen=29, nbytesTransfered=29, ntranslate=31 ********************************************************** And this seems fine, the write and read works and I get back the result which I want. Any ideas about the problem with the streams record? I have attached my IOC startup file too. Thanks, Matthew Attachment:
stgpibdevice.src
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
