1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: RTEMS uC5282 with included tarball
To: Phillip Sorensen <[email protected]>
Cc: [email protected]
Date: Thu, 7 Jun 2007 07:01:40 -0500
On Jun 6, 2007, at 4:08 PM, Phillip Sorensen wrote:
Hi all,
I am stating to work on a project using RTEMS on the uC5282 processor card. I noticed that the source has the ability to use a tarball included in the image for the st.cmd file, etc.
I have not found any documentation on how to build a image with the included tarball, or build the tarball. Does anyone use this feature? How is it done?
You create a tarball of the files you wish to include in the 'in- memory filesystem' and simply append the tarball to the executable image. The tarball filesystem doesn't take away from RAM during operation -- the RTEMS driver implements 'copy on write' . As long as you don't try to write any file the tarball stays completely in flash.
Here's a script I put together that does this and also makes some changes to iocsh environment variables and such. At the moment it adjusts only the 'TOP' iocsh environment variable. It also looks for some APS-specific files in the 'asdstd' directory -- you'll likely want to remove the line that refers to that directory.
Hope this is of some assistance.
Attachment: makeStandaloneIoc.sh
Description: Binary data
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
RTEMS uC5282 with included tarball Phillip Sorensen
Prev: RTEMS uC5282 with included tarball Phillip Sorensen
Next: Automatically generate iocsh registrar code? Susanna Jacobson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
