1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: dm2k not compiling :(
Cc: [email protected]
Date: Wed, 15 Aug 2007 07:48:51 +0200
Jip defnitely have openMotif-dev and not lesstif.
lesstif is installed but not dev package.
Anyways I'm giving up.
As far as I'm concerned DM2K doesn't work.
Neither does EDM.
So it's pretty much MEDM :)
-Heinrich
On Tue, 2007-08-14 at 09:41 -0500, Hammonds, John P. wrote:
> Is it possible that you do not have openMotif installed?  Some
> distributions are including lesstif instead of openMotif.
> John Hammonds
> Beamline and Data Acquisition Group
> APS Engineering Support Division
> Argonne National Laboratory
> [email protected]
> (630)252-5317
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of guobao shen
> Sent: Tuesday, August 14, 2007 6:58 AM
> To: 'Heinrich du Toit'
> Hi Heinrich,
> I compiled the DM2K on my Scientific Linux, and did those exactly you
> did.
> To pass the compilation, I also commented the dld library out. It ran
> smoothly on my pc.
> Guobao
> J-PARC Control Group
> > [mailto:[email protected]] On Behalf Of Heinrich du Toit
> > Sent: Tuesday, August 14, 2007 7:37 PM
> > To: TechTalk EPICS
> > Subject: dm2k not compiling :(
> > I have many problems getting dm2k to compile
> > first of all under graphX/printUtils in dsimple.c:
> > I had to remove the char*malloc; stuff
> > Added stdlib.h include.
> > Also had to fixup char*calloc; somewhere .
> > Then it had #include <xpm.h>
> > So I had to make a symlink to X11/xpm.h
> > then in resourcePallette.c:
> > I had to add: define FLDNAME_SZ 4
> > as for some reason it doesn't get that from the correct .h file..
> > even if I add #include "dm2kCdev.h" ??
> > And now finally it breaks on:
> > g++: /usr/lib/libdld.1: No such file or directory
> > here is the last part of the output from running make:
> > make[2]: Entering directory
> > `/home/heinrich/EPICS/extensions/src/dm2k-2.5.3/dm2k/O.linux-x86'
> > make[3]: Entering directory
> > ../Makefile.Host:410: warning: overriding commands for target `dm2k'
> > /home/heinrich/EPICS/base-3.14.9/config/RULES.Host:428: warning:
> > ignoring old commands for target `dm2k'
> > g++ -ansi -pedantic -o dm2k -g  -Wall -Woverloaded-virtual
> > -Wwrite-strings -Wconversion -Wpointer-arith -Winline   -I../../graphX
> > -I../../xc -I. -DCONFIG_NO_TEAR_OFF -DPROMPT_TO_EXIT=0
> > -DBUILT_AT="\"Tue Aug 14 12:34:32 SAST 2007\""
> > -DBUILT_BY="\"heinrich\""
> > -DDM2K_HELP_PATH="\"http://help.bessy.de/Dm2k\""; -DUSE_XPM
> > -I/usr/X11R6/include/X11 -I/usr/X11R6/include/X11/X11
> > -I/usr/X11R6/include -I/usr/X11R6/include/X11
> > -I/usr/contrib/X11R5/include -D_X86_ -Dlinux -fPIC
> > -D_REENTRANT  -DUNIX -D_BSD_SOURCE -DEXPL_TEMPL -I. -I..
> > -I../../../../include/os/Linux -I../../../../include
> > -I/home/heinrich/EPICS/base-3.14.9/include/os/Linux
> > -D_POSIX_C_SOURCE=199506L      -L../../../../lib/linux-x86/
> > -L/home/heinrich/EPICS/base-3.14.9/lib/linux-x86/ /usr/lib/libdld.1
> > -Wl,-rpath,/home/heinrich/EPICS/extensions/lib/linux-x86
> > -Wl,-rpath,/home/heinrich/EPICS/base-3.14.9/lib/linux-x86
> > -Wl,-rpath,../../../../lib/linux-x86 actions.o amDialog.o
> > browserHelp.o callbacks.o channelPalette.o colorPalette.o
> > display.o dmInit.o eventHandlers.o faceplateBase.o
> > faceplateGUI.o faceplateGUICallback.o faceplateDm2k.o
> > getArchiveData.o help.o help_protocol.o dm2k.o dm2kArc.o
> > dm2kBar.o dm2kByte.o dm2kCartesianPlot.o dm2kChoiceButtons.o
> > dm2kCommon.o dm2kComposite.o dm2kControl.o dm2kDelay.o
> > dm2kDynSymbol.o dm2kImage.o dm2kIndicator.o dm2kMenu.o
> > dm2kMessageButton.o dm2kMeter.o dm2kMonitor.o dm2kOval.o
> > dm2kPixmap.o dm2kPolygon.o dm2kPolyline.o dm2kRectangle.o
> > dm2kRelatedDisplay.o dm2kShellCommand.o dm2kStripChart.o
> > dm2kText.o dm2kTextEntry.o dm2kTextUpdate.o dm2kValuator.o
> > dm2kWidget.o objectPalette.o productDescription.o
> > resourcePalette.o shared.o
> > updateMonitors.o utils.o xgif.o clipbd.o dm2kCA.o    -lJpt -lXpm -lca
> > -lCom -lUnix -lANLwidgets -lPrintUtils -lGraphX -lXm -lXt -lX11 -lXext
> > -lXmu  -lm -lXp -lSM -lICE -ldl   -lpthread -lreadline -lcurses -lrt
> > -lm
> > make[3]: *** [dm2k] Error 1
> > make[3]: Leaving directory
> > make[2]: *** [dm2k] Error 2
> > make[2]: Leaving directory
> > make[1]: *** [buildInstall.linux-x86] Error 2
> > make[1]: Leaving directory
> > `/home/heinrich/EPICS/extensions/src/dm2k-2.5.3/dm2k'
> > make: *** [dm2k.buildInstall] Error 2
> > I'm not trying to compile with CDEV
> > I do have: /usr/lib/libdl.so ect
> > what is libdld ?
> > -Heinrich
dm2k not compiling :( Heinrich du Toit
RE: dm2k not compiling :( guobao shen
RE: dm2k not compiling :( Hammonds, John P.
Prev: bug fixes for R3.14.8.2 Geoff Savage
Next: SDDS? Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: dm2k not compiling :( Hammonds, John P.
Next: a technicality ? Heinrich du Toit
