1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Soft IOC for A GPIB Instrument
To: "Szalata, Zenon M." <[email protected]>
Cc: [email protected]
Date: Mon, 27 Aug 2007 19:03:07 -0700
You need to declare a gpib interface in your stcmd, which you haven't
done. But before you do that you need to compile asyn with gpib support
(LINUX_GPIB=YES). Check the asyn docs. And before your do that you need
to install the linux-gpib libraries.
Finally while configuring /etc/gpib.conf, you need to
associate /dev/gpib0 with the "LO" name (yes that's el-zero!)
Good luck !
E
On Mon, 2007-08-27 at 14:58 -0700, Szalata, Zenon M. wrote:
> I am extremely new to EPICS.  To learn EPICS, I am trying to created an IOC application which would run on linux RedHat Enterprise 3 platform.  I have installed a National Instruments PCI-GPIB interface to which I have connected HP34401A multimeter.  I have installed on the same computer National Instruments software package NI4882, which I believe is the device driver for the PCI-GPIB interface.  In the package NI supplied two test programs, which I built and they work.
> I followed a tutorial "How to create EPICS device support for a simple serial or GPIB device" by Eric Norum to create a support module for the HP multimeter.  Then I created a test application, as it is described in the same tutorial.  I start the test application and this is what I get:
> !--------- start of program output ---------------------------------
> zms@esaux1 $ ../../bin/linux-x86/hpmm st.cmd
> #!../../bin/linux-x86/hpmm
> ## You may have to change hpmm to something else
> ## everywhere it appears in this file
> < envPaths
> epicsEnvSet(ARCH,"linux-x86")
> epicsEnvSet(IOC,"iochpmm")
> epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/esalib/app/epics/hpmm")
> epicsEnvSet(HPMM,"/afs/slac/g/esa/esalib/app/epics/modules/hpmm")
> epicsEnvSet(ASYN,"/afs/slac/g/esa/esalib/app/epics/support/asyn/4-3")
> epicsEnvSet(EPICS_BASE,"/afs/slac/package/epics/R3.14.6/base")
> cd /afs/slac.stanford.edu/g/esa/esalib/app/epics/hpmm
> ## Register all support components
> dbLoadDatabase("dbd/hpmm.dbd",0,0)
> hpmm_registerRecordDeviceDriver(pdbbase)
> ## Load record instances
> cd /afs/slac/g/esa/esalib/app/epics/modules/hpmm
> dbLoadRecords("db/devhpmm.db","P=HPMM:,R=,L=0,A=10")
> cd /afs/slac.stanford.edu/g/esa/esalib/app/epics/hpmm/iocBoot/iochpmm
> iocInit()
> ###  EPICS IOC CORE built on Mar  6 2005
> ###  EPICS R3.14.6 $R3-14-6$ $2004/05/28 19:27:47$
> Starting iocInit
> 2007/08/27 14:28:04.494 devSupportGpib:getDeviceInstance link 0 L0 failed asynManager:connectDevice port L0 not found
> HPMM:hpmm:idn: init_record : no driver for link 0
> HPMM:hpmm:read: init_record : no driver for link 0
> ## Start any sequence programs
> #seq sncxxx,"user=zmsHost"
> iocInit: All initialization complete
> epics>
> !---------- end of program output ---------------------------------------
> In the above, the GPIB number is 0, the instrument primary GPIB address is 10 and its secondary address is 0.
> I do not know how to make a connection between the NI4882 driver and the test application.  I tried something as simpleminded as including a shared library, which is in /usr/local/lib/libgpibapi.so, in the build of the test application.  This had no effect.  The reason I tried that is because the NI test programs used that library when binaries are linked.
> Any help will be greatly appreciated.
> Zen
RE: Soft IOC for A GPIB Instrument Szalata, Zenon M.
Prev: Re: Soft IOC for A GPIB Instrument Benjamin Franksen
Next: gateway problem Yuichi ITOH
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Soft IOC for A GPIB Instrument Szalata, Zenon M.
