Hello Jerome,
The OMS VME58-4S analog output can be configured for either
unipolar (UN command) or biplolar (BI command). The default is
bipolar. Unfortunately, there is no way I know of to query the
controller to determine which mode it is in (it's like a write-only
register).
Check your commands to determine if you are setting the axis to unipolar
mode.
Hope this helps,
Ron
jerome HOSSELET wrote:
Hello
I'm a beginner on EPICS.
I try to command a brushless motor with motor 6.2.2 through OMS58-4S
VME card on EPICS 3.14.8.2 (brushless motor is not a stepper motor).
Actually, I can only move the motor in one direction.
I use for debug a ASCII ligne command.
I found on tech-talk (References: <[email protected]>)
http://www.aps.anl.gov/epics/tech-talk/2001/msg00140.php
that the first command must be: "AT HE KP.1 KD.3 KI0 LP0 HN"
After that i send a move relative positive or negative.
But the motor move always in one direction.
Asking QA command we show a direction have a correct value
AT MR20000 GO
AT QA -> OMS58>PNNH<
AT MR-20000 GO
AT QA -> OMS58>MNNH<
I monitor also analog signal (output voltage for servostar) on output
OMS58-4S. I see for MR20000 a positive voltage and for MR-20000 I
expect a negative voltage but i see a positive voltage more larger
than the first.
Can somebody help me ? or have same troubles ?
thanks per advance
Jerome HOSSELET
- -- Motor move only one direction / Motor 6.2.2 / OMS58-4S / servo-tar 300 -- jerome HOSSELET
Re: -- Motor move only one direction / Motor 6.2.2 / OMS58-4S / servo-tar 300 -- Kurt Goetze
RE: Soft IOC for A GPIB Instrument Szalata, Zenon M.
<2007>
-- Motor move only one direction / Motor 6.2.2 / OMS58-4S / servo-star 300 -- jerome HOSSELET
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
