Thanks Ron and kurt We try to move manually a motor : The encoder counts (.REP field) go up and down accordingly. We have already test "UN" or "BI" in ASCII command but we not seen a difference. if we try "HN" command we can see on scope that VME58 board send negative and positive signal and its oscillate motor move offcourse in both direction. this proove that oms board can produce a negative voltage ( it's not a hardware or connectic problem) but unfortunatly if we send a MR command in both direction the voltage continu to be only positive and the motor in only one direction. It's crazy thanks for any ideas for check begin:vcard fn:Jerome HOSSELET n:HOSSELET;Jerome org:CNRS / IPHC;Electronique / Informatique adr:;;23 rue du loess;Strasbourg;;67000;FRANCE email;internet:[email protected] title:Assistant Ingenieur tel;work:03 88 10 65 30 tel;home:03 88 xx xx xx tel;cell:06 60 xx xx xx note;quoted-printable:Assistant Ing=C3=A9nieur =C3=A0 l' IPHC :=0D=0A= - Projet CMS=0D=0A= - Projet SPIRAL 2 x-mozilla-html:FALSE url:http://ireswww.in2p3.fr/ version:2.1 end:vcard
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
