1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: same PV on multiple IOC's - side effect
To: Heinrich du Toit <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Thu, 27 Sep 2007 10:48:57 -0500
Hi Heinrich,
Heinrich du Toit wrote:
I have 2 network cards in my PC - this is to connect directly to both the campus and the control network here at iThemba LABS.
Now I have eth0 and eth1
If I start an IOC and then look for a PV then both interfaces seem to
return then I get error, although this is the same IOC?
Do you ever expect to have any IOCs on the campus network at all? If not, the solution is to configure the CA client library to send CA searches only to the control network. It is not possible with the current code to tell the IOC server to only export its PVs to a particular network on a machine with multiple interfaces, but as long as the clients only search one network they won't see the problem (for the purposes of the above explanation, the IOC is a client as well as a server).
To tell the client library to only search the control network, set the following two environment variables
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_ADDR_LIST=<broadcast address of control subnet>
The broadcast address is shown on the output from /sbin/ifconfig -a and is probably 172.16.4.255 but it may have different numbers in the 3rd or 4th positions.
As long as those variables are set before you start the IOC and/or any other clients you shouldn't see the duplicate PV warning.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
Re: same PV on multiple IOC's - side effect Emmanuel Mayssat
same PV on multiple IOC's - side effect Heinrich du Toit
Prev: RE: same PV on multiple IOC's - side effect Jeff Hill
Next: Re: same PV on multiple IOC's - side effect Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
