1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: same PV on multiple IOC's - side effect
Cc: TechTalk EPICS <[email protected]>
Date: Thu, 27 Sep 2007 09:25:51 -0700
Andrew,
On Thu, 2007-09-27 at 10:48 -0500, Andrew Johnson wrote:
> To tell the client library to only search the control network, set the
> following two environment variables
>    EPICS_CA_AUTO_ADDR_LIST=NO
>    EPICS_CA_ADDR_LIST=<broadcast address of control subnet>
> The broadcast address is shown on the output from /sbin/ifconfig -a and
> is probably 172.16.4.255 but it may have different numbers in the 3rd or
> 4th positions.
Before I try and for those of us who use non-standard an dmultiple
ports, can I simply set
EPICS_CA_ADDR_LIST="<broadcast>:<port#1> <broadcast>:<port#2>"
Emmanuel
RE: same PV on multiple IOC's - side effect Jeff Hill
same PV on multiple IOC's - side effect Heinrich du Toit
Re: same PV on multiple IOC's - side effect Andrew Johnson
Prev: Re: same PV on multiple IOC's - side effect Andrew Johnson
Next: RE: same PV on multiple IOC's - side effect Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
