1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA inside IOC - shutdown problem
To: TechTalk EPICS <[email protected]>
Date: Fri, 28 Sep 2007 08:41:56 +0200
Hi
I'm running CA in side my IOC.
Everything works fine but at shutdown I get some funny errors at times.
One thing that happens is I get:
epicsThreadOnceOsd epicsMutexLock failed
And other times I get:
epicsThread: Unknown C++ exception in thread "CAC-UDP" at Fri Sep 28
2007 08:39:57.528629432
terminate called after throwing an instance of ''
FATAL: exception not rethrown
Aborted (core dumped)
But this doesn't happen everytime.
Seem to be something todo with timing during exit?
I have a hooked epicsatExit function.
This makes sure ca_clear_channel is called for every CHID I have.
I don't call ca_destroy_context as that seem to be done by shutdown
itself?
Can somebody just give me a tip on what those error messages mean? Then
maybe I can guess what the bug is.
Also sometimes (1 out of 30+ times) I get a segfault while starting the
IOC?  Is it dangerous todo some CA stuff during some stages of the IOC
startup?
Thankyou
Re: CA inside IOC - shutdown problem Andrew Johnson
Prev: RE: same PV on multiple IOC's - side effect Emmanuel Mayssat
Next: EPICS - Future Plans: your Input Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Question about CA and optimization Jeff Hill
Next: Re: CA inside IOC - shutdown problem Andrew Johnson
