This is a known problem on Linux distributions that use the NPTL (the New Posix Thread Library). One thing that happens is I get: epicsThreadOnceOsd epicsMutexLock failed That particular error is an interaction between C++ and the NPTL: NPTL uses the C++ exception mechanism to cause Posix thread cleanup routines to be called when the process exits, but the thing that it throws can't be caught by any C++ code. Unfortunately in EPICS Base we mix Posix and C++, and the result is the above error on shutdown. The error appears to be harmless in my experience. But this doesn't happen everytime. Seem to be something todo with timing during exit? I have a hooked epicsatExit function. This makes sure ca_clear_channel is called for every CHID I have. I don't call ca_destroy_context as that seem to be done by shutdown itself? I'm not sure about the "epicsMutexLock failed" error although it is most likely that it's related, but we do know that the IOC code is not good at shutting itself down cleanly â it was designed to run on an embedded vxWorks CPU whose only job was to run that IOC code, and shutdown wasn't considered to be important functionality. As a result we don't have the mechanisms in place in our APIs to notify records or device support to shut themselves down. It's likely that we will not be able to properly address this problem in current versions of EPICS, although if/when we redesign the record and device APIs shutdown will be one of the design requirements. Also sometimes (1 out of 30+ times) I get a segfault while starting the IOC? Is it dangerous todo some CA stuff during some stages of the IOC startup? You should probably avoid using the CA client library before the startup script's call to iocInit has completed. After that is fine, but do register an epicsAtExit() routine (after iocInit) and have that stop any threads and CA calls from occurring afterwards. - Andrew -- When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong. -- Arthur C. Clarke
ANJ, 10 Nov 2011 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
