1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Beacon and caRepeater
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Mon, 01 Oct 2007 14:36:09 -0500
Hi Emmanuel,
Several of the questions you are asking were covered in detail by Ken Evans' "Channel Access in Depth" talk, the slides for which are available at (PDF File):
http://www.aps.anl.gov/aod/bcda/epicsgettingstarted/specialtopics/ChannelAccessInDepth1up.pdf
I suggest you read that and then come back here with any questions it didn't answer or let you work out.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
Beacon and caRepeater Emmanuel Mayssat
Prev: Beacon and caRepeater Emmanuel Mayssat
Next: RE: Beacon and caRepeater Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
