1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Beacon and caRepeater
To: [email protected]
Date: Mon, 01 Oct 2007 12:23:05 -0700
Hello all,
I currently have some client applications which do not reconnect to my
server once an IOC is restarted (after 24h of being shutdown).
I want to solve that issue.
My current understanding of the way CA clients is the following:
When a client is started, it attempts to fetch the PV according the
EPICS_CA_ADDR_LIST (default port if not explicit is
EPICS_CA_SERVER_PORT)
If the client still cannot find a PV, it sends another search requests
to all servers listed in EPICS_CA_ADDR_LIST. It continues doing at
increasing intervals. At one point it will stop sending search requests.
Q: Are search request TCP based?
At that point the only thing that can wake it up is a beacon anomaly.
Q: Who/what detects beacon anomalies? Is it the caRepeater?
Beacon are sent by IOC server as soon as they are started.
Beacon are UDP broadcasted by IOC server from EPICS_CA_SERVER_PORT to
EPICS_CA_REPEATER_PORT at the frequency given by
EPICS_CA_BEACON_PERIOD.
Q: Where are the beacon sent? IP address? Port? transport protocol?
If caRepeater daemon was spawned on client, it receives the beacons,
detect a beacon anomaly and inform the registered clients that some new
PVs are available.
Q: Is it possible that the caRepeater is not spawn? (for ex if not in
client application path)
Q: What happens if you have several caRepeater processes running on
client? Do they maintain the same list of registered client processes?
On some of my machines, I have several caRepeater processes...
Q: How can I list all clients registered with a caRepeater?
Q: What if server and client do not have the same
EPICS_CA_REPEATER_PORT? The beacon should not be sent by the IOC server
to the right location of the repeater, is this correct?
( I think this is the problem I have)
Q: Should the EPICS_CA_REPEATER_PORT be the same on all IOC servers and
OPI clients?
Q: If the client had initially connected but then the IOC server goes
down, is the procedure the same? When are state of health messages sent?
Emmanuel
Re: Beacon and caRepeater Andrew Johnson
RE: Beacon and caRepeater Jeff Hill
Prev: Re: Support module for KS3988 camac crate controller. Mauro Giacchini
Next: Re: Beacon and caRepeater Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
