1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Beacon and caRepeater
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Mon, 01 Oct 2007 17:12:45 -0700
On Mon, 2007-10-01 at 15:47 -0600, Jeff Hill wrote:
> Starting with EPICS R3.14.7 this maximum search rate interval plateau in
> seconds is determined by the EPICS_CA_MAX_SEARCH_PERIOD environment
> variable.
That's an interesting feature
> Beacon anomalies are detected by the client library (in the client
> application's process). The repeater daemon is just a fan-out engine.
ok
> The client subscribes with the CA repeater using the EPICS_CA_REPEATER_PORT
> it is configured with.
Ok, so possibly I have several caRepeater because the
EPICS_CA_REPEATER_PORT was not the same when the client were started.
> The server sends beacons to the address list configured by
> EPICS_CAS_AUTO_BEACON_ADDR_LIST and EPICS_CAS_BEACON_ADDR_LIST. If ports are
> not configured there, then they are specified by EPICS_CAS_BEACON_PORT.
According to a previous thread,
http://www.aps.anl.gov/epics/tech-talk/2007/msg00273.php
the EPICS_CAS_* environment variables are only for "new CAS server".
So when I build my IOC servers are they running on the new or the old CA
server libraries?
E
RE: Beacon and caRepeater Jeff Hill
Beacon and caRepeater Emmanuel Mayssat
Prev: RE: Beacon and caRepeater Jeff Hill
Next: RE: Beacon and caRepeater Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
