1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Beacon and caRepeater
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Tue, 02 Oct 2007 18:00:44 -0700
On Mon, 2007-10-01 at 15:47 -0600, Jeff Hill wrote:
> The rate at which name resolution (search) requests are sent exponentially
> backs off to a plateau rate. The value of this plateau has an impact on
> network traffic because it determines the rate that clients search for
> channel names that are miss-spelled or otherwise don't exist in a server.
> Furthermore, for clients that are unable to see the beacon from a new
> server, the plateau rate may also determine the maximum interval that the
> client will wait until discovering a new server.
> Starting with EPICS R3.14.7 this maximum search rate interval plateau in
> seconds is determined by the EPICS_CA_MAX_SEARCH_PERIOD environment
> variable.
This obviously implies recompilation of the extensions (medm, etc)
against the new base, isn't it?
In my case, my medm doesn't work correctly with 3.14.6+
http://www.aps.anl.gov/epics/tech-talk/2007/msg00744.php
Could that be related to channel access?
I am now able to make sense of the details of the CA client - CA server
communication.
EPICS_CA_ADDR_LIST is a list of servers where to send search requests
EPICS_CAS_BEACON_ADDR_LIST is a list of repeaters where to send beacons
But then why do we have EPICS_CAS_BEACON_LIST default to the value of
EPICS_CA_ADDR_LIST if the former is not set? Can we send beacons and
search requests to the same port? That doesn't make any sense to me...
Emmanuel
RE: Beacon and caRepeater Jeff Hill
Beacon and caRepeater Emmanuel Mayssat
Prev: RE: Beacon and caRepeater Ernest L. Williams Jr.
Next: Using Asyn driver or modifying devLib (or related programs) of EPICS base for any knid of cPCI cards Jenny Chen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Beacon and caRepeater Jeff Hill
