If I have a custom record...
And it has some procedure to respond to an ASYN interrupt.
As I understand it this asyn interrupt run in a different thread than
the dbaccess for the record?
This means in effect that if I have some array field and start editing
it in the interrupt function.
Then the db access/ca can get half-way modified values back?
Which would be bad?
Any method that the array can mutex/lock its fields while processing
them?
Or is it ok to edit?
- RE: asyn interrupt and record Mark Rivers
RE: firewire video on RTEMS-4.6.x-MVME5500 Pearson, MR (Matthew)
softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Dirk Zimoch
<2007>
StreamDevice 2-3 released Dirk Zimoch
<2007>
