1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn interrupt and record
To: "Heinrich du Toit" <[email protected]>, "TechTalk EPICS" <[email protected]>
Date: Fri, 12 Oct 2007 09:07:05 -0500
> This means in effect that if I have some array field and start editing
> it in the interrupt function.
> Then the db access/ca can get half-way modified values back?
No, that is not a problem.  The interrupt callback will call dbScanLock to lock the record before it modifies anything.  Of course that can block, but if the database is built correctly then it will not block for long, because any asynchronous processing will be happening in other threads.  This is the standard EPICS method to avoid conflicts with record processing.
From: [email protected] on behalf of Heinrich du Toit
Sent: Fri 10/12/2007 5:36 AM
To: TechTalk EPICS
Subject: asyn interrupt and record
If I have a custom record...
And it has some procedure to respond to an ASYN interrupt.
As I understand it this asyn interrupt run in a different thread than
the dbaccess for the record?
Which would be bad?
Any method that the array can mutex/lock its fields while processing
them?
Or is it ok to edit?
asyn interrupt and record Heinrich du Toit
Prev: Re: firewire video on RTEMS-4.6.x-MVME5500 Kate Feng
Next: Re: softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: asyn interrupt and record Heinrich du Toit
Next: softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Dirk Zimoch
