1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Configuring Detectors with Different Software
To: "Jeffrey Lipton" <[email protected]>, <[email protected]>
Date: Sat, 3 Nov 2007 11:43:05 -0500
Hi Jeffrey,
You definitely cannot have EPICS gather data through the Kepler program. Kepler is not designed to operate as a "server", it is a stand-alone client.
You also cannot use Kepler to configure the Saturn and use EPICS to just collect data.  The EPICS software uses the XIA Handel library, which requires a call to xiaInit().  That does a complete restart of the Saturn, including downloading the firmware and blowing away any existing settings.
However, this should not be a problem.  The EPICS software provides complete control over all settings on the Saturn via the "dxp" record.  So any configuration that you do in Kepler you can do equally well with EPICS.  Is there something specific that you have found that you can do in Kepler and cannot do in EPICS?
From: [email protected] on behalf of Jeffrey Lipton
Sent: Fri 11/2/2007 1:44 PM
To: [email protected]
Subject: Configuring Detectors with Different Software
Hello,
                Thanks for helping with my build issues with EPICS. I am currently trying to set up a Radiant Vortex Detector (XIA Saturn backend). I would like to use Kepler software to configure the device and record Data using EPICS. Is it possible to  use the Kepler configuration settings which include values not set in the EPICS DXP config files? Is there a way for me to have EPICS gather data through the Kepler program? And suggestions would be greatly appreciated.
Jeffrey Ian Lipton
Laboratory Asisstant
CHESS
203-415-9267
Configuring Detectors with Different Software Jeffrey Lipton
Prev: Re: lexical analyzer for .db? Noboru Yamamoto
Next: Re: lexical analyzer for .db? Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Configuring Detectors with Different Software Jeffrey Lipton
Next: EPICS on Mac OS X 10.5 Bertrand H.J. Biritz
