1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: lexical analyzer for .db?
To: [email protected]
Date: Sun, 4 Nov 2007 21:23:16 +0100
On Freitag, 2. November 2007, Eric Norum wrote:
> On Nov 2, 2007, at 8:30 AM, Ned Arnold wrote:
> > You may be able to eliminate the fanout records by careful design
> > of forward links and/or input link flags (PP, CP, etc).
> > For example, if the input record's forward link field referenced
> > the calc record and the calc record's forward link field referenced
> > the calcout record, all would process each time the input record
> > processed ... without a fanout.
> Don't take this technique to extremes, though.  I recall helping
> Steve Shoaf diagnose problems with his database for a video switching
> system.  The database contained 128 records FLNK'd together.  This
> caused very weird IOC faults that we finally realized were caused by
> stack overflow of the task processing the records -- 128 recursive
> calls to the record processing routine forced the task stack pointer
> past the end of the stack space.
Indeed, in one application (a feed-forward from insertion device positions
to quadrupole currents) that connects about 30 inputs and 40 outputs and
does some non-trivial processing in-between, I found the system to behave a
lot more reliable and predictable if all records get periodically scanned,
compared to the use of .CP links, FLNKs etc. Order of processing between
the stages is imposed via setting the PHAS field (I use 4 different
values).
Cheers
Ben
lexical analyzer for .db? Heinrich du Toit
Re: lexical analyzer for .db? Ned Arnold
Re: lexical analyzer for .db? Eric Norum
Prev: RE: Configuring Detectors with Different Software Mark Rivers
Next: EPICS on Mac OS X 10.5 Bertrand H.J. Biritz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: lexical analyzer for .db? Ralph Lange
Next: Re: lexical analyzer for .db? Emmanuel Mayssat
