1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subArray INDX field set to 0 if NORD <= 0
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Fri, 16 Nov 2007 16:34:33 -0600
Hi Lewis,
J. Lewis Muir wrote:
Have you made any more progress with this? Or are you waiting on a response from Carl to your below email from a week ago?
I just heard back from Carl who sent me another patch which I have applied.
I'm willing to do a little testing if you have a patch you'd like someone to try out.
Great, I'm attaching the latest subArrayRecord.c file to this email (it has gone through too many cosmetic changes since R3.14.9 to be worth using a .patch file) which I have compiled but not tested. Please check it out and report back.
â Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
* Copyright (c) 2002 Lawrence Berkeley Laboratory,The Control Systems
*     Group, Systems Engineering Department
* EPICS BASE Versions 3.13.7
* and higher are distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
/* recSubArray.c */
/* recSubArray.c - Record Support Routines for SubArray records
 *      Author:         Carl Lionberger
 *      Date:           090293
 *      NOTES:
 * Derived from waveform record.
 * Modification Log:
#include <stddef.h>
#include <stdlib.h>
#include <stdarg.h>
#include <stdio.h>
#include <string.h>
#include "dbDefs.h"
#include "epicsPrint.h"
#include "alarm.h"
#include "dbAccess.h"
#include "dbEvent.h"
#include "dbFldTypes.h"
#include "dbScan.h"
#include "devSup.h"
#include "errMdef.h"
#include "recSup.h"
#include "recGbl.h"
#define GEN_SIZE_OFFSET
#include "subArrayRecord.h"
#undef  GEN_SIZE_OFFSET
#include "epicsExport.h"
/* Create RSET - Record Support Entry Table*/
#define report NULL
#define initialize NULL
static long init_record(subArrayRecord *psa, int pass);
static long process(subArrayRecord *psa);
#define special NULL
#define get_value NULL
static long cvt_dbaddr(DBADDR *paddr);
static long get_array_info(DBADDR *paddr, long *no_elements, long *offset);
static long put_array_info(DBADDR *paddr, long nNew);
static long get_units(DBADDR *paddr, char *units);
static long get_precision(DBADDR *paddr, long *precision);
#define get_enum_str NULL
#define get_enum_strs NULL
#define put_enum_str NULL
static long get_graphic_double(DBADDR *paddr, struct dbr_grDouble *pgd);
static long get_control_double(DBADDR *paddr, struct dbr_ctrlDouble *pcd);
#define get_alarm_double NULL
rset subArrayRSET={
        RSETNUMBER,
        report,
        initialize,
        init_record,
        process,
        special,
        get_value,
        cvt_dbaddr,
        get_array_info,
        put_array_info,
        get_units,
        get_precision,
        get_enum_str,
        get_enum_strs,
        put_enum_str,
        get_graphic_double,
        get_control_double,
        get_alarm_double
epicsExportAddress(rset,subArrayRSET);
struct sadset { /* subArray dset */
        long            number;
        DEVSUPFUN       dev_report;
        DEVSUPFUN       init;
        DEVSUPFUN       init_record; /*returns: (-1,0)=>(failure,success)*/
        DEVSUPFUN       get_ioint_info;
        DEVSUPFUN       read_sa; /*returns: (-1,0)=>(failure,success)*/
/*sizes of field types*/
static int sizeofTypes[] = {MAX_STRING_SIZE,1,1,2,2,4,4,4,8,2};
static void monitor(subArrayRecord *psa);
static long readValue(subArrayRecord *psa);
    struct sadset *pdset;
    if (pass==0){
        if (psa->malm <= 0)
            psa->malm = 1;
        if (psa->ftvl > DBF_ENUM)
            psa->ftvl = 2;
        psa->bptr = calloc(psa->malm, sizeofTypes[psa->ftvl]);
        psa->nord = 0;
        return 0;
    /* must have dset defined */
    if (!(pdset = (struct sadset *)(psa->dset))) {
        recGblRecordError(S_dev_noDSET,(void *)psa,"sa: init_record");
        return S_dev_noDSET;
    /* must have read_sa function defined */
    if ( (pdset->number < 5) || (pdset->read_sa == NULL) ) {
        recGblRecordError(S_dev_missingSup,(void *)psa,"sa: init_record");
        return S_dev_missingSup;
    if (pdset->init_record)
        return (*pdset->init_record)(psa);
    return 0;
    struct sadset *pdset = (struct sadset *)(psa->dset);
    long           status;
    unsigned char  pact=psa->pact;
    if ((pdset==NULL) || (pdset->read_sa==NULL)) {
        psa->pact=TRUE;
        recGblRecordError(S_dev_missingSup, (void *)psa, "read_sa");
    if (pact && psa->busy) return 0;
    status=readValue(psa); /* read the new value */
    if (!pact && psa->pact) return 0;
    psa->pact = TRUE;
    recGblGetTimeStamp(psa);
    psa->udf = !!status; /* 0 or 1 */
    if (status)
        recGblSetSevr(psa, UDF_ALARM, INVALID_ALARM);
    monitor(psa);
    /* process the forward scan link record */
    recGblFwdLink(psa);
    psa->pact=FALSE;
    return 0;
    subArrayRecord *psa = (subArrayRecord *) paddr->precord;
    paddr->pfield = psa->bptr;
    paddr->no_elements = psa->malm;
    paddr->field_type = psa->ftvl;
    paddr->field_size = sizeofTypes[psa->ftvl];
    paddr->dbr_field_type = psa->ftvl;
    return 0;
    if (psa->udf)
       *no_elements = 0;
    else
       *no_elements = psa->nord;
    *offset = 0;
    return 0;
    if (nNew > psa->malm)
       psa->nord = psa->malm;
    else
       psa->nord = nNew;
    return 0;
    strncpy(units, psa->egu, DB_UNITS_SIZE);
    return 0;
    int fieldIndex = dbGetFieldIndex(paddr);
    *precision = psa->prec;
    if (fieldIndex != subArrayRecordVAL)
        recGblGetPrec(paddr, precision);
    return 0;
    switch (dbGetFieldIndex(paddr)) {
    case subArrayRecordVAL:
        pgd->upper_disp_limit = psa->hopr;
        pgd->lower_disp_limit = psa->lopr;
        break;
    case subArrayRecordINDX:
        pgd->upper_disp_limit = psa->malm - 1;
        pgd->lower_disp_limit = 0;
        break;
    case subArrayRecordNELM:
        pgd->upper_disp_limit = psa->malm;
        pgd->lower_disp_limit = 1;
        break;
    default:
        recGblGetGraphicDouble(paddr, pgd);
    return 0;
        pcd->upper_ctrl_limit = psa->hopr;
        pcd->lower_ctrl_limit = psa->lopr;
        break;
        pcd->upper_ctrl_limit = psa->malm - 1;
        pcd->lower_ctrl_limit = 0;
        break;
        pcd->upper_ctrl_limit = psa->malm;
        pcd->lower_ctrl_limit = 1;
        break;
    default:
        recGblGetControlDouble(paddr, pcd);
    return 0;
    unsigned short monitor_mask;
    monitor_mask = recGblResetAlarms(psa);
    monitor_mask |= (DBE_LOG|DBE_VALUE);
    db_post_events(psa, psa->bptr, monitor_mask);
    return;
    long            status;
    struct sadset   *pdset = (struct sadset *) (psa->dset);
    if (psa->nelm > psa->malm)
        psa->nelm = psa->malm;
    if (psa->indx >= psa->malm)
        psa->indx = psa->malm - 1;
    status = (*pdset->read_sa)(psa);
    if (psa->nord <= 0)
        status = -1;
    return status;
Re: subArray INDX field set to 0 if NORD <= 0 J. Lewis Muir
RE: subArray INDX field set to 0 if NORD <= 0 Gillingham, IJ (Ian)
Re: subArray INDX field set to 0 if NORD <= 0 Carl Lionberger
Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
Prev: Re: SDDS lapack compile error Janet Anderson
Next: fanout processing and timed-out records Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: subArray INDX field set to 0 if NORD <= 0 J. Lewis Muir
Next: Re: subArray INDX field set to 0 if NORD <= 0 J. Lewis Muir
