1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with assert in dbLock.c
To: <[email protected]>
Date: Mon, 19 Nov 2007 13:45:51 -0600
Let the tests run much longer, and here's the final score.
bash-3.2$ gmake -s runtests
epicsUnitTestTest..........ok
epicsCalcTest..............ok
epicsAlgorithmTest.........ok
epicsMathTest..............ok
epicsStdioTest.............ok
epicsStringTest............ok
epicsTimeTest..............ok
epicsThreadTest............ok
epicsThreadPriorityTest....ok
epicsThreadPrivateTest.....ok
epicsExitTest..............ok
epicsTimerTest.............FAILED tests 2-3
        Failed 2/40 tests, 95.00% okay
ringPointerTest............ok
epicsEventTest.............ok
epicsMutexTest.............ok
epicsExceptionTest.........ok
epicsMessageQueueTest......ok
macEnvExpandTest...........ok
blockingSockTest...........ok
Failed Test      Stat Wstat Total Fail  Failed  List of Failed
epicsTimerTest.t               40    2   5.00%  2-3
Failed 1/19 test scripts, 94.74% okay. 2/1306 subtests failed, 99.85%
okay.
gmake[3]: *** [runtests] Error 255
gmake[2]: *** [runtests.netbsd-x86] Error 2
gmake[1]: *** [libCom/test.runtests] Error 2
gmake: *** [src.runtests] Error 2
bash-3.2$
The timer test is the only item that failed, it looks like.
Where do I look for that?
David
>>> Eric Norum <[email protected]> 11/19/2007 1:34 PM >>>
On Nov 19, 2007, at 1:26 PM, David Dudley wrote:
> Got farther, but not all the way.  I assume that the
> MessageQueueTest shouldn't take 'minutes', as none of the others
> took over at most about 5-10 seconds.
> Not sure what the timer test failing is.  It was working before,
> and looks like an upgrade must have killed it.  Also, it isn't very
> consistent.  I've seen it fail tests 2-5, 2-4, and 2-3 at various
> times.  The MessageQueTest runs for quite a while, and then I
> killed it.
Actually the message queue test *is* supposed to run for a while.  It
even says so:
ok 55 - Send with no receiver
ok 56 - receive into undersized buffer returned error (-1)
# Single receiver, single sender tests:
#   priority-based scheduler, sent 4 messages
#   scheduler not strict priority, sent 5 messages
ok 57 - 10 of 10 messages sent with sender pauses
# Single receiver, multiple sender tests:
# This test takes 5 minutes...
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Re: Problem with assert in dbLock.c Eric Norum
Re: Problem with assert in dbLock.c Andrew Johnson
Problem with assert in dbLock.c David Dudley
Re: Problem with assert in dbLock.c David Dudley
Prev: Re: Problem with assert in dbLock.c Eric Norum
Next: Re: Problem with assert in dbLock.c Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
