1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with assert in dbLock.c
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Mon, 19 Nov 2007 14:06:45 -0600
David Dudley wrote:
epicsTimerTest.............FAILED tests 2-3 Failed 2/40 tests, 95.00% okay
Not sure what the timer test failing is. It was working before, and looks like an upgrade must have killed it. Also, it isn't very
Actually that test is probably too sensitive, it's just reporting that your timers didn't fire within some nominal accuracy which is not really necessary for EPICS to work properly (and fails for me on Linux fairly often if my machine is busy). The important point is that you've fixed the Mutex test, so I think you're now golden.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
Problem with assert in dbLock.c David Dudley
Re: Problem with assert in dbLock.c Andrew Johnson
Re: Problem with assert in dbLock.c David Dudley
Re: Problem with assert in dbLock.c Eric Norum
Prev: Re: Problem with assert in dbLock.c David Dudley
Next: Re: subArray INDX field set to 0 if NORD <= 0 J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: 2007 EPICS Meeting (Knoxville) Presentations Kay-Uwe Kasemir
