1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with assert in dbLock.c
To: <[email protected]>
Date: Mon, 19 Nov 2007 14:00:25 -0600
Well, everything seems to work, but have a problem with accuracy.  It
isn't consistent, with an error of 0.011... but relatively close.
Rebuilding everything makes the system work without problem, now.
David
>>> Eric Norum <[email protected]> 11/19/2007 1:51 PM >>>
On Nov 19, 2007, at 1:45 PM, David Dudley wrote:
> Let the tests run much longer, and here's the final score.
> The timer test is the only item that failed, it looks like.
> Where do I look for that?
cd <epics_top>/src/libCom/test
Then run the test by hand.  Here's what I do for Mac OS X -- you'll
have to make appropriate substitutions (replace darwin-x86 with
netbsd-x86) for your host architecture.
  ./O.darwin-x86/epicsTimerTest
1..40
# Testing timer accuracy
ok  1 - timerCount == nTimers
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Problem with assert in dbLock.c David Dudley
Re: Problem with assert in dbLock.c Andrew Johnson
Re: Problem with assert in dbLock.c David Dudley
Re: Problem with assert in dbLock.c Eric Norum
Prev: Re: Problem with assert in dbLock.c Eric Norum
Next: Re: Problem with assert in dbLock.c Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
