1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: building EPICS base on Mac OS X 10.5 (Leopard)
To: [email protected]
Cc: [email protected]
Date: Tue, 20 Nov 2007 08:00:09 -0500
I discovered that the problem was due to an incomplete installation of developer tools. Specifically, the scripts which get put into /usr/ bin to support multiple developer tool installation were missing. If you have installed the CHUD performance tools, it is important to first uninstall the CHUD performance tools before installing Xcode 3.0. The CHUD performance tools come with an uninstaller application.
After I uninstalled the CHUD performance tools and then reinstalled Xcode 3.0, I was able to build EPICS after applying the finite/ isfinite patch posted in previous tech talk postings.
thanks,
tom
On Nov 19, 2007, at 8:34 PM, [email protected] wrote:
Here is a list of /usr/libexec/gcc on my MacOSX10.5 machine.
 /usr/libexec/gcc:
 total used in directory 0 available 446416
 drwxr-xr-x   5 root  wheel   170 Oct 31 08:41 .
 drwxr-xr-x@ 94 root  wheel  3196 Oct 31 08:41 ..
 drwxr-xr-x   6 root  wheel   204 Sep 24 07:42 darwin
 drwxr-xr-x   3 root  wheel   102 Sep 24 07:37 i686-apple-darwin9
 drwxr-xr-x   3 root  wheel   102 Sep 24 07:37 powerpc-apple-darwin9
and contents in /usr/lib/exec/gcc/darwin
  /usr/libexec/gcc/darwin:
 drwxr-xr-x  6 root  wheel  204 Sep 24 07:42 .
 drwxr-xr-x  5 root  wheel  170 Oct 31 08:41 ..
 drwxr-xr-x  3 root  wheel  102 Sep 24 07:43 i386
 drwxr-xr-x  3 root  wheel  102 Sep 24 07:43 ppc
 drwxr-xr-x  3 root  wheel  102 Sep 24 07:43 ppc64
 drwxr-xr-x  3 root  wheel  102 Sep 24 07:43 x86_64
The error message you sent says:
include -I/sw/include   ../../../src/libCom/bucketLib/bucketLib.c
/usr/libexec/gcc/i686-apple-darwin8/4.0.1/as: assembler (/usr/bin/../
libexec/gcc/darwin/i386/as or /usr/bin/../local/libexec/gcc/darwin/
i386/as) for architecture i386 not installed
Installed assemblers are:
/usr/bin/../libexec/gcc/darwin/ppc64/as for architecture ppc64
/usr/bin/../libexec/gcc/darwin/x86_64/as for architecture x86_64
So, I suggest to check your installation of Xcode.
my Env:
bash-3.2$ uname -a
Darwin xxx.yyy.zzz 9.0.0 Darwin Kernel Version 9.0.0: Tue Oct 9 21:37:58 PDT 2007; root:xnu-1228~\1/RELEASE_PPC Power Macintosh
bash-3.2$ cc --version
powerpc-apple-darwin9-gcc-4.0.1 (GCC) 4.0.1 (Apple Inc. build 5465)
Copyright (C) 2005 Free Software Foundation, Inc.
You need to install epicsMath.h from Eric.
You may also need to edit configure/os/CONFIG.Common.darwin-ppcx86 to
delete
-isysroot /Developer/SDKs/MacOSX10.4u.sdk
and
-Wl,-syslibroot,/Developer/SDKs/MacOSX10.4u.sdk
from options.
Hope this help,
Noboru
--- "Tom Pelaia" <[email protected]> ---
Has anyone successfully built EPICS base 3.14.9 on Mac OS X 10.5
(Leopard) for X86?  It fails when I attempt to run make.
thanks,
tom
I get the following result and error when running make:
t6p@i73072: make
make -C config install
perl /Library/EPICS/Versions/Current/configure/tools/makeMakefile.pl
O.darwin-x86 ../..
mkdir O.Common
make -C O.darwin-x86 -f ../Makefile TOP=../.. T_A=darwin-x86 install
make[2]: Nothing to be done for `install'.
make -C configure install
O.darwin-x86 ../..
mkdir O.Common
perl /Library/EPICS/Versions/Current/configure/tools/ convertRelease.pl
-h darwin-x86 CONFIG_APP_INCLUDE
make -C src install
make -C libCom install
O.darwin-x86 ../../..
mkdir O.Common
make -C O.darwin-x86 -f ../Makefile TOP=../../.. T_A=darwin-x86 install
perl ../../../src/libCom/misc/makeEpicsVersion.pl /Library/EPICS/
Versions/Current/configure/CONFIG_BASE_VERSION ../O.Common
Building epicsVersion.h from /Library/EPICS/Versions/Current/ configure/
CONFIG_BASE_VERSION
Found EPICS Version 3.14.9
Installing generated generic include file ../../../include/
epicsVersion.h
/usr/bin/cc -c -DUNIX -Ddarwin -ansi -O3 -Wall
-fno-common -fPIC -I. -I.. -I../../../src/libCom/bucketLib - I../../../
src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/
cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/
cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ ellLib -
I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/
libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/
gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -
I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/
libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/ tsDefs
-I../../../include/os/Darwin -I../../../include -I/opt/local/
make[3]: *** [bucketLib.o] Error 1
make[2]: *** [install.darwin-x86] Error 2
make[1]: *** [libCom.install] Error 2
make: *** [src.install] Error 2
t6p@i73072:
building EPICS base on Mac OS X 10.5 (Leopard) Tom Pelaia
Re: building EPICS base on Mac OS X 10.5 (Leopard) yamamoto
Prev: RE: building EPICS base on Mac OS X 10.5 (Leopard) Denison, PN (Peter)
Next: Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: building EPICS base on Mac OS X 10.5 (Leopard) yamamoto
Next: RE: building EPICS base on Mac OS X 10.5 (Leopard) Denison, PN (Peter)
