1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: building EPICS base on Mac OS X 10.5 (Leopard)
To: "Tom Pelaia"<[email protected]>, [email protected]
Date: Tue, 20 Nov 2007 10:34:29 +0900 (JST)
Here is a list of /usr/libexec/gcc on my MacOSX10.5 machine.
  /usr/libexec/gcc:
  total used in directory 0 available 446416
  drwxr-xr-x   5 root  wheel   170 Oct 31 08:41 .
  drwxr-xr-x@ 94 root  wheel  3196 Oct 31 08:41 ..
  drwxr-xr-x   6 root  wheel   204 Sep 24 07:42 darwin
  drwxr-xr-x   3 root  wheel   102 Sep 24 07:37 i686-apple-darwin9
  drwxr-xr-x   3 root  wheel   102 Sep 24 07:37 powerpc-apple-darwin9
and contents in /usr/lib/exec/gcc/darwin
   /usr/libexec/gcc/darwin:
  drwxr-xr-x  6 root  wheel  204 Sep 24 07:42 .
  drwxr-xr-x  5 root  wheel  170 Oct 31 08:41 ..
  drwxr-xr-x  3 root  wheel  102 Sep 24 07:43 i386
  drwxr-xr-x  3 root  wheel  102 Sep 24 07:43 ppc
  drwxr-xr-x  3 root  wheel  102 Sep 24 07:43 ppc64
  drwxr-xr-x  3 root  wheel  102 Sep 24 07:43 x86_64
The error message you sent says:
>include -I/sw/include   ../../../src/libCom/bucketLib/bucketLib.c
>/usr/libexec/gcc/i686-apple-darwin8/4.0.1/as: assembler (/usr/bin/../
>libexec/gcc/darwin/i386/as or /usr/bin/../local/libexec/gcc/darwin/
>i386/as) for architecture i386 not installed
>Installed assemblers are:
>/usr/bin/../libexec/gcc/darwin/ppc64/as for architecture ppc64
>/usr/bin/../libexec/gcc/darwin/x86_64/as for architecture x86_64
So, I suggest to check your installation of Xcode.
my Env:
bash-3.2$ uname -a
Darwin xxx.yyy.zzz 9.0.0 Darwin Kernel Version 9.0.0: Tue Oct  9 21:37:58 PDT 2007; root:xnu-1228~\1/RELEASE_PPC Power Macintosh
bash-3.2$ cc --version
powerpc-apple-darwin9-gcc-4.0.1 (GCC) 4.0.1 (Apple Inc. build 5465)
Copyright (C) 2005 Free Software Foundation, Inc.
You need to install epicsMath.h from Eric.
You may also need to edit configure/os/CONFIG.Common.darwin-ppcx86 to
delete
-isysroot /Developer/SDKs/MacOSX10.4u.sdk
and
-Wl,-syslibroot,/Developer/SDKs/MacOSX10.4u.sdk
from options.
Hope this help,
Noboru
--- "Tom Pelaia" <[email protected]> ---
>Has anyone successfully built EPICS base 3.14.9 on Mac OS X 10.5
>(Leopard) for X86?  It fails when I attempt to run make.
>thanks,
>tom
>I get the following result and error when running make:
>t6p@i73072: make
>make -C config install
>perl /Library/EPICS/Versions/Current/configure/tools/makeMakefile.pl
>O.darwin-x86 ../..
>mkdir O.Common
>make -C O.darwin-x86 -f ../Makefile TOP=../.. T_A=darwin-x86 install
>make[2]: Nothing to be done for `install'.
>make -C configure install
>O.darwin-x86 ../..
>mkdir O.Common
>perl /Library/EPICS/Versions/Current/configure/tools/convertRelease.pl
>-h darwin-x86 CONFIG_APP_INCLUDE
>make -C src install
>make -C libCom install
>O.darwin-x86 ../../..
>mkdir O.Common
>make -C O.darwin-x86 -f ../Makefile TOP=../../.. T_A=darwin-x86 install
>perl ../../../src/libCom/misc/makeEpicsVersion.pl /Library/EPICS/
>Versions/Current/configure/CONFIG_BASE_VERSION ../O.Common
>Building epicsVersion.h from /Library/EPICS/Versions/Current/configure/
>CONFIG_BASE_VERSION
>Found EPICS Version 3.14.9
>Installing generated generic include file ../../../include/
>epicsVersion.h
>/usr/bin/cc -c            -DUNIX  -Ddarwin   -ansi  -O3  -Wall
>-fno-common -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../
>src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/
>cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/
>cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -
>I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/
>libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/
>gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -
>I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/
>libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs
>-I../../../include/os/Darwin -I../../../include       -I/opt/local/
>make[3]: *** [bucketLib.o] Error 1
>make[2]: *** [install.darwin-x86] Error 2
>make[1]: *** [libCom.install] Error 2
>make: *** [src.install] Error 2
>t6p@i73072:
Re: building EPICS base on Mac OS X 10.5 (Leopard) Tom Pelaia
Prev: Re: subArray INDX field set to 0 if NORD <= 0 J. Lewis Muir
Next: RE: building EPICS base on Mac OS X 10.5 (Leopard) Denison, PN (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: building EPICS base on Mac OS X 10.5 (Leopard) Tom Pelaia
Next: Re: building EPICS base on Mac OS X 10.5 (Leopard) Tom Pelaia
