1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stream Raw converter and un/signed integrer
To: Emmanuel Mayssat <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Wed, 21 Nov 2007 16:46:25 +0100
Hi Emmanuel,
I patched the RawConverter to support both signed and unsigned conversion. To stay backward compatible, %r converts signed. I use %0r for unsigned now.
The new version is attached.
Dirk
Emmanuel Mayssat wrote:
Dirk,
I hope you are doing well.
I was wondering if you had the time to look at unsigned conversion for
the raw converter.
You are probably busy, so I can work on this patch myself if need be.
Please let me know as I am anxiously waiting for this feature.
Emmanuel
On Fri, 2007-11-09 at 09:57 -0800, Emmanuel Mayssat wrote:
Dirk,
Is it possible to get a patch for unsigned conversion ?
I would prefer that to additional records as there are many of them.
( I am converting an existing driver to stream)
Please let me know.
I looked at the code, I think it is just a matter of changing signed
char to unsigned char and adding a new flag in the code of the
converter.
E
On Wed, 2007-10-31 at 11:26 +0100, Dirk Zimoch wrote:
Hi Emmanuel,
It should be sufficient to pass the value through a calc record that does "A&65535".
I will probably add a flag to do unsigned conversion.
Dirk
Hello all,
I am using stream and a 16 bit word to convert to an unsigned integer (0
to 64xxx). The unsigned integer is coded on 2 characters.
So I use the raw converter and particularly %2.2r
But with that converter then the integer is signed (as mentioned in the
doc). So I can read values between 0 to 32767 and -32768 to -1.
Is there a way to use unsigned integer with the raw converter or do I
have to write my own converter?
Looking at the RawConverter.cc code, I am afraid that I will have to
write my own...
Emmanuel
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
* StreamDevice Support                                         *
* (C) 1999 Dirk Zimoch ([email protected])          *
* (C) 2005 Dirk Zimoch ([email protected])                    *
* This is the raw format converter of StreamDevice.            *
* Please refer to the HTML files in ../doc/ for a detailed     *
* documentation.                                               *
* If you do any changes in this file, you are not allowed to   *
* redistribute it any more. If there is a bug or a missing     *
* feature, send me an email and/or your patch. If I accept     *
* your changes, they will go to the next release.              *
* DISCLAIMER: If this software breaks something or harms       *
* someone, it's your problem.                                  *
#include "StreamFormatConverter.h"
#include "StreamError.h"
// Raw Bytes Converter %r
class RawConverter : public StreamFormatConverter
    int parse(const StreamFormat&, StreamBuffer&, const char*&, bool);
    bool printLong(const StreamFormat&, StreamBuffer&, long);
    int scanLong(const StreamFormat&, const char*, long&);
int RawConverter::
    const char*&, bool)
    return long_format;
bool RawConverter::
printLong(const StreamFormat& format, StreamBuffer& output, long value)
    int prec = format.prec;   // number of bytes from value
    if (prec == -1) prec = 1; // default: 1 byte
    int width = prec;         // number of bytes in output
    if (format.width > width) width = format.width;
    char byte = 0;
    if (format.flags & alt_flag) // lsb first (little endian)
        while (prec--)
            byte = static_cast<char>(value);
            output.append(byte);
            value >>= 8;
            width--;
        if (format.flags & zero_flag)
            // fill with zero
            byte = 0;
        else
            // fill with sign
            byte = (byte & 0x80) ? 0xFF : 0x00;
        while (width--)
    else // msb first (big endian)
            // fill with zero
            byte = 0;
        else
            // fill with sign
            byte = ((value >> (8 * (prec-1))) & 0x80) ? 0xFF : 0x00;
        while (width > prec)
            width--;
        while (prec--)
            output.append(static_cast<char>(value >> (8 * prec)));
    return true;
int RawConverter::
scanLong(const StreamFormat& format, const char* input, long& value)
    long length = 0;
    long val = 0;
    int width = format.width;
    if (width == 0) width = 1; // default: 1 byte
    if (format.flags & skip_flag)
        return width; // just skip input
        // little endian (sign extended)*/
        unsigned int shift = 0;
        while (--width && shift < sizeof(long)*8)
            val |= ((unsigned char) input[length++]) << shift;
            shift += 8;
        if (width == 0)
                // fill with zero
            else
                // fill with sign
                val |= ((signed char) input[length++]) << shift;
        length += width; // ignore upper bytes not fitting in long
    else
        // big endian */
            // fill with zero
            val = (unsigned char) input[length++];
        else
            // fill with sign
            val = (signed char) input[length++];
        while (--width)
            val <<= 8;
            val |= (unsigned char) input[length++];
    value = val;
    return length;
RegisterConverter (RawConverter, "r");
Stream Raw converter and un/signed integrer Emmanuel Mayssat
Re: Stream Raw converter and un/signed integrer Dirk Zimoch
Re: Stream Raw converter and un/signed integrer Emmanuel Mayssat
Prev: RE: VDCT Hierarchies Shepherd, EL (Emma)
Next: Re: Streams questions (how to read +00011-01 as 11e-01=1.1) Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stream Raw converter and un/signed integrer Emmanuel Mayssat
Next: edd 1-11-0gz seg fault Kevin Tsubota
