MEDM version 3.03 : Your record has three state strings for states #0, 1 and 2, but the VAL field is set to 3 which does not correspond to a valid state. Either you need to define a fourth state string, or change the record so it is never set to the value 3. This is not a bug in MEDM. A minor patch stops the warining message: This change would add an off-by-one bug to MEDM, which we will not do. As the warning message states, there are only three defined states for this record starting at state number 0. With your fix in place, try putting the integer value 4 into that MBBO record and you'll get the same problem, showing that you haven't fixed what you think you have. - Andrew -- When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong. -- Arthur C. Clarke
ANJ, 10 Nov 2011 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
