Andrew Johnson wrote:
> Kate Feng wrote:
> > MEDM version 3.03 :
> > When I defined only three states for a mbbo record,
> > the following warning message will pop up whenever CA is
> > connected.
> > menuUpdateValueCb: Got state 3.
> > Only have strings for 3 states (starting at 0).
> > Kate:Mset_formatmode
> Your record has three state strings for states #0, 1 and 2, but the VAL
> field is set to 3 which does not correspond to a valid state. Either
> you need to define a fourth state string, or change the record so it is
> never set to the value 3. This is not a bug in MEDM.
It was really a modular problem in my application . I found out that
the error message was triggered only because I forgot to specify 'rval'
on that particualr mbbo record in the init_mbbo_record(). This is the
reason why 'val' was set to an unknown state instead of the one
I specified.
Kate
- A patch for medm Kate Feng
- Re: A patch for medm Andrew Johnson
RE: Help with udev Dr. Peter Hartmann
RE: Help with udev Mark Rivers
<2007>
2025
Re: A patch for medm Kate Feng
genSub and EFLG John Dobbins
<2007>
2025
