1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA wishlist :)
To: [email protected]
Date: Sat, 15 Dec 2007 18:40:32 +0100
On Mittwoch, 12. Dezember 2007, Jeff Hill wrote:
> > Then a question:
> > Can somebody explain the relationship between.
> > ca_flush_io
> > ca_poll
> > ca_pend_io
> > ca_pend_event
> My intent was that this is documented in the manual, but I should reread
> that section. CA is an asynchronous batch oriented communication system.
> This tends to allow for high performance, but its interactions are
> somewhat more complex compared to round trip blocking communications
> interfaces.
> In summary, the ca_pend_io function blocks until all ordinary
> (non-callback) get requests (issued since the last call to ca_pend_io)
> complete or its timeout expires. If, when creating a channel, one does
> not specify a connection callback, then ca_pend_io will also block for
> this type of channel to connect (if the channel is created after the last
> call to ca_pend_io). This is the _only_ purpose of ca_pend_io.
> The ca_flush_io function blocks until it finishes forcing all requests in
> the output queue to be delivered to the client side input of the TCP
> circuit. This is the _only_ purpose of ca_flush_io.
> The ca_pend_event function is for use only in non-preemptive mode
> clients. Its sole purpose is for periodically processing CA client
> library background activities that wouldn't get a chance to run if the
> single thread of control does not pass periodically through the CA client
> library. CA client library background activities include, but are not
> limited to, sending search requests, receiving search responses,
> receiving beacon messages, receiving TCP messages, and calling callbacks.
> The ca_pend_event function waits for a specified interval. If there is CA
> related labor to do it will use CPU otherwise it will sleep for the
> specified interval. If the interval parameter is zero it will be taken as
> a shortcut for an infinite interval. The ca_poll function calls
> ca_pend_event with a very short, but not zero, delay interval.
> > And which ones of these I don't have to call in a enabled pre-emptive
> > callback environment?
> No polling is required if preemptive callback mode is enabled so the
> ca_pend_event (and ca_poll) functions aren't useful for that type of
> client. The ca_pend_io function is only useful to short lifespan types of
> clients and is therefore not particularly useful in preemptive mode
> clients, and certainly never useful other than in the main thread (the
> thread that created the ca context). The ca_flush_io function will be
> quite useful in preemptive mode (serving exactly the same function it
> serves in the other mode).
Hi Jeff
this is a very concise and clear explanation that you could include verbatim
in the CA Client Lib manual. Or maybe create a CA FAQ, starting with the
above two questions and their answers? On the epics wiki, perhaps?
Cheers
Ben
CA wishlist :) Heinrich du Toit
RE: CA wishlist :) Jeff Hill
Prev: First announcement on the next EPICS collaboration meeting /EPICS seminar SQLiu
Next: EPICS Codeathon, 14-18 April 2008 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA wishlist :) J. Lewis Muir
Next: vxworks driver 4 realtek 8139? marco_hair
