1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Help with udev
To: [email protected]
Cc: "Scott D. Davilla" <[email protected]>, [email protected]
Date: Wed, 02 Jan 2008 11:22:58 -0500
On 12/21/07 2:15 PM, Mark Rivers wrote:
> That is the good news. The bad news is that setting the permissions
> on that device, /dev/bus/usb/005/018 does not allow a non-privileged
> user to access the device. In order for a non-privileged use to
> access the device, I find that I need to set the permissions to 666
> on /proc/bus/usb/005/018 i.e. the /proc filesystem, not the /dev
> filesystem. If I change the permissions on the /proc filesystem
> manually then I can run the IOC in a non-privileged account.
> I am not a Linux expert by any means. What is the difference between
> the /dev and /proc filesystems? Peter also mentioned the /sys file
> system. How is that related?
> I am using the libusb library to access the device. With that API one
> simply calls usb_find_busses and usb_find_devices to locate the device
> you are interested in. You don't specify the file system anywhere.
> Any ideas how to get the permissions I need set on the device?
> Thanks, Mark
Hi, Mark.
Maybe the libusb library is using /proc/bus/usb as the virtual file system instead of /dev/bus/usb. What happens if you set the USB_DEVFS_PATH environment variable to "/dev/bus/usb" in the process environment of your IOC?
-lewis
Re: Help with udev Emmanuel Mayssat
RE: Help with udev Mark Rivers
Prev: Re: problem running application in asyn4-6 Eric Norum
Next: RE: Ca error Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Help with udev Emmanuel Mayssat
