1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: build snl program
To: åæç <[email protected]>
Cc: [email protected]
Date: Thu, 03 Jan 2008 11:23:07 -0800
It seems that your makefile doesn't know how to compile the st snl
program. It is probably because it cannot find the SEQ
binaries/libraries.
Did you remember to run "make" in the configure directory after changing
the RELEASE file? I always found this step counter intuitive...
BTW, is SNCSEQ set correctly? Shouldn't the sequencer be installed
outside of the base tree, let's say
in /home/rtems/epics-extras-3.14.6/seq-2.11 ?
Emmanuel
On Thu, 2008-01-03 at 08:39 +0800, åæç wrote:
> cIOC1PScontrol.st is in the same directory as the file Makefile, and I set the
> variable
> SNCSEQ=/home/rtems/base3.14.6/base/src/sequence
> in the file base/configure/REALEASE, but after make, the error still appears.
> can you provide some details when you install SNC and set enrionment variable?
> Thanks!
> Haoli Shi
Re: build snl program 师昊礼
Prev: Re: build snl program 师昊礼
Next: problem in running application of PSM6003 zhangdemin99
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
