1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problem in running application of PSM6003
To: [email protected]
Date: Fri, 4 Jan 2008 15:55:04 +0800 (CST)
Dear all,
  Thanks Norum for your attention, and now it works well.But
there is another problem when running appilication which I have
built for the NI power supply connected to the PC with PCI-GPIB
board.I have built the driver NI-4882 package for the board.
In the st.cmd file,I only add GpibBoardDriverConfig("L0",1,0,3,0),
but it says this command not found. Is it linux-gpib not built well?
I have built linux-gpib like this:
(1)cp /boot/config-2.6.9-67.EL /usr/src/kernels/2.6.9-67.EL-i686
(2)cd /usr/src/kernels/2.6.9-67.EL-i686
(3)make oldconfig
(4)make dep
(5)cd <linux-gpib>
(6)./configure
(7)make
(8)make install
It also says L0 not found, what should I do next?
many thanks in advance
[fel@localhost ~]$ cd EPICS/psm6003/iocBoot/iocPSM6003
[fel@localhost iocPSM6003]$ ../../bin/linux-x86/PSM6003 st.cmd
#!../../bin/linux-x86/PSM6003
## You may have to change PSM6003 to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"iocPSM6003")
epicsEnvSet(TOP,"/home/fel/EPICS/psm6003")
epicsEnvSet(PSM6003,"/home/fel/EPICS/module/psm6003")
epicsEnvSet(ASYN,"/home/fel/EPICS/4-6")
epicsEnvSet(EPICS_BASE,"/home/fel/EPICS/base")
cd /home/fel/EPICS/psm6003
dbLoadDatabase("dbd/PSM6003.dbd",0,0)
PSM6003_registerRecordDeviceDriver(pdbbase)
## Load record instances
#dbLoadRecords("db/xxx.db","user=felHost")
dbLoadRecords("db/devPSM6003.db","user=felHost")
st.cmd -- Line 18 -- Command GpibBoardDriverConfig not found.
iocInit()
Starting iocInit
## EPICS R3.14.9- $R3-14-9-pre1$ $2006/11/20 21:09:36$
## EPICS Base built Dec 30 2007
2008/01/04 11:16:54.163 devSupportGpib:getDeviceInstance link 0 L0 failed asynMa nager:connectDevice port L0 not found
current-in: init_record : no driver for link 0
current-out: init_record : no driver for link 0
iocInit: All initialization complete
## Start any sequence programs
#seq sncxxx,"user=felHost"
The CA server's beacon address list was empty after initialization?
epics>
Best wishes
        deminzhang
网 易 有 道 词 典 -- 全 球 最 强 大 的 免 费 英 汉 互 译 词 典 ( 只 有 2 兆 )
Re: problem in running application of PSM6003 Emmanuel Mayssat
Prev: Re: build snl program Emmanuel Mayssat
Next: Re: problem in running application of PSM6003 Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
