1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem in running application of PSM6003
To: zhangdemin99 <[email protected]>
Cc: [email protected]
Date: Fri, 04 Jan 2008 10:32:50 -0800
On Fri, 2008-01-04 at 15:55 +0800, zhangdemin99 wrote:
> Dear all,
> (2)cd /usr/src/kernels/2.6.9-67.EL-i686
> (3)make oldconfig
> (4)make dep
> (5)cd <linux-gpib>
> (6)./configure
> (7)make
> (8)make install
> It also says L0 not found, what should I do next?
Are the gpib driver installed in the kernel module
directory? /lib/modules/<kernel_version>/gpib
Did you load the gpib drivers? ( you have to modprobe something. If your
card is supported by linux-gpib, which drivers should you load?)
Finally you need to configure the modules in /etc/gpib.conf (that is
where you specify the interface name LO)
> GpibBoardDriverConfig("L0",1,0,3,0)
> st.cmd -- Line 18 -- Command GpibBoardDriverConfig not found.
> iocInit()
asyn doesn't include GPIB support by default.
I believe you need to set the LINUX_GPIB to yes in the asyn RELEASE
file. Please refer to the asyn docs.
Cheers,
Emmanuel
problem in running application of PSM6003 zhangdemin99
Prev: problem in running application of PSM6003 zhangdemin99
Next: RE:problem in running application of PSM6003 zhangdemin99
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
