1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME Toaster - has anyone else experienced this?
To: "Gillingham, IJ \(Ian\)" <[email protected]>
Cc: [email protected]
Date: Thu, 10 Jan 2008 08:56:58 +0100
we have had similar incidents with the MAXv's predecessor, the OMS58 card. In that case the reason was bad design
of that card: a capacitor is placed too close to the card border and its 5v-side pin touches the ESD (electrostatic discharge)
strip on a VME64x crate (OMS58 is of course not designed for VME64x, but even in the old standard this
placement was not acceptable). The card then pulled a lot of current from the backplane, eventually burning the pins,
the (P1) connector and the backplane slot.
best regards,
Timo
Gillingham, IJ (Ian) wrote:
On the night of 30th December 2007, a fire broke out in one of our control system's VME crates. Considerable damage was inflicted on the crate, but fortunately the fire did not spread. On examination of the crate and VME cards, the P1 connector, to which a "MAXv 8000" card was connected, had been destroyed by heat/flame. Electrical burning of some components was evident on the MAXv card, these components were well away from the direct heat of the main area of combustion (components close to the fire were of course destroyed).
We are presently trying to ascertain which component caused the failure (the MAXv card, P1 connector or VME backplane).
Has anyone else experienced this type of event, in particular with the MAXv motor control card?
Ian Gillingham Diamond Light Source
Timo Korhonen PSI (Paul Scherrer Institut, http://www.psi.ch) CH-5232 Villigen PSI tel + 41- 56 3103262 fax + 41 - 56 310 3383 e-mail: [email protected]
VME Toaster - has anyone else experienced this? Gillingham, IJ (Ian)
Prev: Re: VME Toaster - has anyone else experienced this? Tim Mooney
Next: Re: RTEMS-mvme5500 BSP Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VME Toaster - has anyone else experienced this? Kurt Goetze
Next: EDM Motif Widget Rendering John Dobbins
