As what I have stated previously privately that
there are known bugs unrelated to your problems, in the version
of the mvme5500 BSP you have that I discourage you from using it,
especially knowing that you are using it for the powerSupply. This
is all I can say until the EPICS LICENSE issue is resolved between
the mvme5500 BSP that I wrote and the beatnik BSP that Till
Straumann wrote after mvme5500 BSP was released.
I can not send you the new kernel until this issue is resolved. I do
not think you can use beatnik leagally at thie point before it's resolved, either.
I will try to answer you the questions below as much as I can, but
I do not see it as mvme5500 BSP related or OS related. I recommend
that you take an EPICS and RTEMS training and have all questions
solved there. I remember that there is an EPICS workshop/training
to be held in China this Spring.
ʦê»Àñ wrote:
> My EPICS base version is 3.14.6, the same as you use.
> I locate sequencer source codes under base/src/sequence, and then
> modify the file configure/RELEASE(add the following lines)
> EPICS_BASE=/home/rtems/base-3.14.6/base
> TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
> modify the file configure/CONFIG_SITE
> PVCA = TRUE
> CROSS_COMPILER_TARGET_ARCHS = RTEMS-mvme5500
> and then under the directory /home/rtems/base-3.14.6/base/src/sequence, then make.
> add the line to .cshrc
> set path=(/home/rtems/base-3.14.6/base/sequence/bin/linux-x86 $path)
I did not try sequence with RTEMS yet, but it should not be OS dependent.
Look at the linux-x86.
Obviously, the PATH is wrong if you intended to use RTEMS. Depending
on the configuration of the Makefile, it should be something like
/home/rtems/base-3.14.6/base/sequence/bin/RTEMS-mvme5500 or
/home/rtems/base-3.14.6/bin/RTEMS-mvme5500 instead of
/home/rtems/base-3.14.6/base/sequence/bin/linux-x86.
Kate
> then add a line to the file /home/rtems/base-3.14.6/base/configure/RELEASE
> SCNSEQ=/home/rtems/base-3.14.6/base/src/sequence
> in my epics application, part of Makefile is as follows:
> ifneq ($(SNCSEQ),)
> # This builds sncExample as a component of power_supply
> power_supply_DBD += sncExample.dbd
> power_supply_SRCS += sncExample.stt
> power_supply_LIBS += seq pv
> # The following builds myProgram as a standalone application
> PROD_HOST += myProgram
> myProgram_SNCFLAGS += +m
> myProgram_SRCS += myProgram.st
> myProgram_LIBS += seq pv
> myProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
> endif
> power_supply_LIBS += $(EPICS_BASE_IOC_LIBS)
> and then make, an error appears:
> make[1]: *** No rule to make target `myProgram.o', needed by `myProgram'. Stop.
> Could you give me the latest kernel and try? any colleagues did not install
> snc under EPICS 3.14.X, so it's a problem to me.
> thanks again!
> Haoli Shi
> First, I think the version of the mvme5500 BSP that
> you use have a known bug at run-time, which,
> unfortunately, I can not discolsed any further until
> I have resolved the issue of the EPICS license violation,
> which was caused by the beatnik BPS that is written
> by Till STraumann of SLAC.
> Thus, I do discourage you from using it with
> the power supply.
> 1) Unresolved symbol: pdevLibVirtualOS
> I do not have this problem.
> Which version of EPICS do you use ?
> 2) SNCSEQ should not have to do with any BSP.
> It depends on how you set the Makefile.
> Kate
Re: VME Toaster - has anyone else experienced this? Korhonen Timo
VXI11 GPIB and asynRecord Eric Williams
<2008>
EDM Motif Widget Rendering John Dobbins
<2008>
