1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: CA connection management problem
To: "'Owens, PH \(Peter\)'" <[email protected]>, <[email protected]>
Date: Thu, 17 Jan 2008 09:32:40 -0700
>  Here is a simple test using the  EPICS caget
Agree with Andrew that this is a somewhat usual way to use the CA client
library. Nevertheless, the symptoms as reported smells like a bug. I created
mantis entry 306 to tack progress on the issue.
Thanks for documenting the symptoms,
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Owens, PH (Peter)
> Sent: Thursday, January 17, 2008 3:54 AM
> To: [email protected]
> Subject: CA connection management problem
> From: Victor F E Pucknell [mailto:[email protected]]
> Sent: 16 January 2008 15:01
> To: Duggan, AJ (Andrew)
> Cc: Owens, PH (Peter); Letts, SC (Simon)
> Subject: EPICS problem
>    Normally it is in a loop using caget every 2 seconds.
> If you  "quit"  the EPICS server then I get a serious failure  and the
test
> program is lost somewhere in the ca library
> Here is the output from the test program
> ca_pend_io returned with rc=0x1: value=0x0 ca_get returned with rc=0x1
> CA.Client.Exception...............................................
>     Warning: "Virtual circuit disconnect"
>     Context: "nndhcp069.dl.ac.uk:5064"
>     Source File: ../cac.cpp line 1126
>     Current Time: Wed Jan 16 2008 14:46:01.574167550
>     Context: "op=0, channel=MEIS-B-A-201:STA, type=DBR_SHORT, count=1,
> ctx="nndhcp069.dl.ac.uk:5064""
>     Source File: ../getCopy.cpp line 86
>     Current Time: Wed Jan 16 2008 14:46:01.574311751
> ca_pend_io failed User specified timeout on IO operation expired ca_get
> failed Virtual circuit disconnect EPICS server failure - resetting
> A call to "assert (_pTargetMutex == & mutexToVerify)" failed in
> ../../../include/epicsGuard.h line 84.
> EPICS Release EPICS R3.14.9-3.14.9 $R3-14-9$ $2007/02/05 16:31:45$.
> Current time Wed Jan 16 2008 14:46:08.582331945.
> Please E-mail this message to Jeff Hill [email protected] or to tech-
> [email protected] Calling epicsThreadSuspendSelf()
> However if kill the EPICS server using Control+C then the application does
> seem to recover and resume once I restart the EPICS server.
>     Current Time: Wed Jan 16 2008 14:50:41.049109570
>     Current Time: Wed Jan 16 2008 14:50:41.049255811
> ca_get failed Virtual circuit disconnect
> Attempting start....
> calling ca_context_create
> calling ca_create_channel
> calling ca_pend_io
> calling ca_pend_io
> This was not an exhaustive trial. I tried each only a couple of times.
> However the asset failure and the suspend is typical of what we see.
> Vic
CA connection management problem Owens, PH (Peter)
Prev: Re: CA connection management problem Andrew Johnson
Next: Re: CA connection management problem Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: CA connection management - vxWorks David Maden
Next: error in communicating to the GPIB device with NI-PCI board zhangdemin99
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
