Subject: Re: Multiple target os-class application build
To: Sue Witherspoon <[email protected]>
Cc: [email protected]
Date: Mon, 25 Feb 2008 14:56:11 -0600
Hi Sue,
>     I sent this question thru tech-talk while tech-talk 'seemed to be
> down'. The question did come up two days later but I got no response
> at
> all.
We had a mailman outage last week which delayed a whole lot of messages after a python upgrade on our webserver; I hope it's all fixed now.
>    I have an application that will run on a vxWorks ioc and an RTEMS
> ioc.  Obviously, there are some functions that are peculiar to
> vxWorks.
> The Makefile Definitions allow for this by using <app>_SRCS_<osclass>
> or vxWorksOnly_SRCS etc.  But is there a
> tag or definition for the DBD files that would differentiate between
> vxWorks and  RTEMS?
> I'm using Epics 3.14.8.2.
DBD files are universal, meaning that we don't create a separate expanded DBD file for each target architecture we're building for; in fact they get expanded inside the O.Common directory which all arch's use.  If you have some DBD entries that are specific to a particular architecture, you've going to have to create a seperate expanded DBD file for that arch.  However this isn't generally as hard as it might seem, since you can use variable substitutions in the Makefile to create the various different versions without duplicating everything.  Here's an example snippet, untested though since I'm at home right now:
PROD_IOC = app
DBD += unix.dbd rtems.dbd vxworks.dbd
common_DBD += base.dbd
common_DBD += allArchs.dbd
unix_DBD += $(common_DBD)
unix_DBD += unixOnly.dbd
rtems_DBD += $(common_DBD)
rtems_DBD += rtemsOnly.dbd
vxworks_DBD += $(common_DBD)
vxworks_DBD += vxworksOnly.dbd
# <name>_registerRecordDeviceDriver.cpp is created from <name>.dbd
app_SRCS_DEFAULT += unix_registerRecordDeviceDriver.cpp
app_SRCS_RTEMS += rtems_registerRecordDeviceDriver.cpp
app_SRCS_vxWorks += vxworks_registerRecordDeviceDriver.cpp
app_SRCS_DEFAULT += appMain.cpp
app_LIBS += $(EPICS_BASE_IOC_LIBS)
HTH,
- Andrew
RE: Multiple target os-class application build Mark Rivers
Re: Multiple target os-class application build Sue Witherspoon
Prev: RE: Problem with soft motor record Shepherd, EL (Emma)
Next: Re: calc record LINK error Benjamin Franksen
Prev: Multiple target os-class application build Sue Witherspoon
Next: RE: Multiple target os-class application build Mark Rivers
