Kristi,
Here's an equivalent Koyu system, for which there is an EPICS driver:
D2-03B-1 3 SLOT BASE WITH INTERNAL 110/220 VAC P/S 119.00
D2-230 CPU RLL/RLL PLUS 2.4K WDS 139.00
F2-08AD-2 8 CH ANALOG INPUT VOLTAGE 12-BIT RES 264.00
F2-02DA-2 2 CH ANALOG OUTPUT VOLTAGE 12 BIT RESOLUTION 163.00
D2-16ND3-2 16PT 24VDC SINK SOURCE INPUT 82.00
D2-16TD1-2 16PT 12-24VDC SINK (2TERM) 0.1A/PT 1.6A/MODULE 89.00
H2-ECOM100 100MBIT DL205 ETHERNET COMMUNICATION MODULE 299.00
Subtotal: $1155.00
I don't have experience with touch panel screens.
Here is a 10" panel from them:
EA7-T10C 10 IN, COLOR, TFT TOUCH PANEL WITH ETHERNET & USB, SUPPORTS COMPACT FLASH $1,575.00
I have used the Optimate 1212, which has 12 pushbuttons and 12 lamps. Each can be nicely labeled, and the buttons can be set to be momentary or alternate, and may work instead of a touch panel.
OM1212 Lamp/Pushbutton Module $ 269.00
From: [email protected] on behalf of Luchini, Kristi
Sent: Mon 3/17/2008 7:42 PM
To: [email protected]
Cc: Lam, Briant
Subject: Inexpensive PLC Ethernet w/EPICS Driver
Hello,
Can anyone suggest a low-cost options for a plc w/ethernet, touch panel and an existing epics driver?
We current we are looking at the IDEC PLC and Mark Rivers recommended the Koyu from Automation Direct which works with MODBUS.
- Thanks,
Kristi
PLC (IDEC) Hardware
Model Description Cost
FC5A-D16RK1 Processor $ 248
FC4A-HPC1 RS232 Module $ 44
FCA-ENET Ethernet Module $ 249 http://www.idec.com/language/english/manual/WebServerModuleManual.pdf
FC4A-J8C1 8 Channel (diff) Ai $ 260
FC4A-K2C1 2 Channel Ao $ 139
FC4A-N16B3 16 Channel Di $ 136
FC4A-N16S3 16 Channel Do $ 192
HG3F-FT22TFB 10.4 Inch Touch Panel $1650
BX1D-S20A Terminal Block $ 29
FC9Z-H100A20 Terminal Block Cable $ 34
FC4A-KC2CA PLC-to Touch Panel Cable $ 20
-----Original Message-----
Sent: Monday, March 10, 2008 12:43 PM
To: Luchini, Kristi; [email protected]
Cc: Lam, Briant
Subject: RE: PLC Ethernet Driver for the IDEC MicroLogix 1100
Hi Kristi,
I could not find an online manual for the FC4A-ENET. However, some
documentation I saw online for the FC5A-D16RK1 suggests that it is
Modbus compatible. If so, then you may be able to use my Modbus driver,
which works with Ethernet or serial:
http://cars.uchicago.edu/software/epics/modbus.html
Note that Koyu PLCs from Automation Direct are also less expensive than
Allen Bradley, and they are definitely Modbus compatible.
> [mailto:[email protected]] On Behalf Of Luchini, Kristi
> Sent: Monday, March 10, 2008 12:45 PM
> Cc: Lam, Briant
> Subject: PLC Ethernet Driver for the IDEC MicroLogix 1100
> Hello,
> Has anyone written an EPICC PLC Ethernet Driver for the IDEC
> ethernet module FC4A-ENET
> using MicroLogic 1100. The processor is model FC5A-D16RK1
> This is a much cheaper PLC Model than Allen-Bradley and we
> hope that someone else out there may have already had some
> experience with this hardware.
> Thanks
> - Kristi
- PLC Ethernet Driver for the IDEC MicroLogix 1100 Luchini, Kristi
- RE: PLC Ethernet Driver for the IDEC MicroLogix 1100 Mark Rivers
- Inexpensive PLC Ethernet w/EPICS Driver Luchini, Kristi
RE: Inexpensive PLC Ethernet w/EPICS Driver Mark Rivers
<2008>
2025
<2008>
2025
