What does the first number in parenthesis mean? Something like an element count. For this sick connection it was 54! Please look at theattachment. One common bug that can cause such a large number of connections is if the channel connection callback routine creates a new subscription whenever a channel connection comes up, even if it already had a subscription from the last time it connected. The application in question here appears to be the DESY archiver which is likely to have an effect on a large number of IOCs, so I would strongly recommend that this code be reviewed for incorrect channel subscription logic. A strong indication that this kind of bug is present is if the number increases over an IOC reboot and decreases over an application restart. The best would be to disconnect all CA connections and give back (at least a part of) the additionally allocated memory back to the system pool. Note that this IOC is running R3.13.10 on vxWorks 5.3.1; if my memory is correct, this is using the old (pre-SENS) TCP/IP stack, so its network buffer management is very different to the SENS stack which has fixed buffer sizes. The earlier stack could (and did) call malloc() to get new buffers after initialization time. Also, if the memory is being used up by a multiple subscription bug in a client this kind of memory pool rework would make no difference anyway. - Andrew -- When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong. -- Arthur C. Clarke
ANJ, 02 Sep 2010 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
