On Tue, 2008-03-18 at 13:09 +0100, Korhonen Timo wrote:
> set to the same number. The ai record could then look like this:
> record(ai, "Test:RecordToProcessOnEvent1or2") {
> field(SCAN, "Event")
> field(EVNT, "1")
> #EVNT is the soft event number
> ...other ai fields here...
The problem with this method is that you have to keep track of the event
numbers in use. I believe epics support only 256 events. If a device
driver sends the same event ~number~ than the one expected by another
driver, then you are toasted!
> This way you do not have to FLNK to each record, and there are also
> other possibilities
With FLNK you don't have the same issue
> to dispatch the events, like from a calcout record (using OEVT and
> OOPT). Usually this is
> much more flexible method for the applications.
Interesting. I never noticed that calcout records could be configured to
generate events.
> > record(event, "Test:Event1") {
> > field(DTYP, "MRF Event Receiver")
> > field(INP, "#C0 S1 @")
> > field(SCAN, "I/O Intr")
> > field(VAL, "1")
> > field(FLNK, "Test:RecordToProcessOnEvent1or2")
When I red the above, I was a little confused.
event records are usually generating events, not receiving them.(source
epics record manual). The record above seems to be using a DTYP I am
unfamiliar with. Where can I find the source? Is that event driver
specific?
Cheers,
E
- RE: Listen to multiple events Allison, Stephanie
- Re: Listen to multiple events Korhonen Timo
- Listen to multiple events Dehong Zhang
Re: Memory Problem related to CA? Andrew Johnson
<2008>
<2008>
