Emmanuel Mayssat wrote:
On Tue, 2008-03-18 at 13:09 +0100, Korhonen Timo wrote:
set to the same number. The ai record could then look like this:
record(ai, "Test:RecordToProcessOnEvent1or2") {
field(SCAN, "Event")
field(EVNT, "1")
#EVNT is the soft event number
...other ai fields here...
The problem with this method is that you have to keep track of the event
numbers in use. I believe epics support only 256 events. If a device
driver sends the same event ~number~ than the one expected by another
driver, then you are toasted!
Well, there is no free lunch ;-)
However, it is anyway a good idea to keep track of the events
and (IMHO) a small price to pay for the flexibility you get with that
method.
The 'soft' event numbers need only to be unique per IOC. Hard coding the
event
number in a driver would not be a very good idea. Usually this is done
in the record level
(like the event or calcout records) so the numbers can be managed by the
app developer
in the record configuration.
As Stephanie pointed out, this discussion was specific to event
receivers, but of course
nothing stops one from implementing a similar method for other hardware.
best regards,
Timo
Timo Korhonen PSI (Paul Scherrer Institut, http://www.psi.ch)
CH-5232 Villigen PSI
tel + 41- 56 3103262 fax + 41 - 56 310 3383
e-mail: [email protected]
- Listen to multiple events Dehong Zhang
- RE: Listen to multiple events Allison, Stephanie
- Re: Listen to multiple events Korhonen Timo
- Re: Listen to multiple events Emmanuel Mayssat
Severity of I/O interrupt records Schuh, Stephen
RE: Severity of I/O interrupt records Shepherd, EL (Emma)
<2008>
EDM cursors. Terry Carlino
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
