Chris Slominski wrote: ld<systemO/system.munch sysAtReboot() is a routine you need to add to your vxWorks BSP/boot image which provides a way to get around the fundamental design flaw that Wind River made with their rebootHook facility — that the hook routines are called in the same order that they are registered rather than in reverse order. This means that the TCP/IP network stack shuts down before the application running on top of it ever gets notified, so it is not possible for the application to close any network connections nicely. The sysAtReboot facility registers its rebootHook *before* the network stack gets initialized, so our epicsAtExit() routines now get called before the network gets taken off-line. I described the BSP changes you need in this tech-talk message: http://www.aps.anl.gov/epics/tech-talk/2005/msg00004.php If you have any questions about that code just let me know. If you can't make those changes immediately, you can add this line to the top of your st.cmd scripts which will at least ensure that the epicsAtExit() routines get called, but they still won't be able to clean up any network sockets. rebootHookAdd(epicsExitCallAtExits) - Andrew -- When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong. -- Arthur C. Clarke
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
