Hi all,
Unfortunately, Emma is wrong. Because of the way how %(myRecord.fieldName) is
implemented, myRecord is never processed when the read does not succeed. I just
don't get to the point to find out about myRecord when there is no input to parse.
Also forwarding connection problems to I/O Intr records is not don in
StreamDevice yet. Because it is not supported by asyn, I would have to add a yet
another hack and have my own list of I/O Intr connected to any particular asyn
port/address. That is something I can probably do.
Dirk
Shepherd, EL (Emma) wrote:
Hi Stephen,
One thing you could do is to change your implementation slightly. Make
your I/O interrupt records Passive, and change your protocol to
explicitly map each part of the message to the required records using
the "%(myRecord.fieldName)" syntax of format converters.
I'm fairly sure this should make the records go invalid if communication
fails... but someone correct me if I'm wrong.
Emma
-----Original Message-----
[mailto:[email protected]] On Behalf Of Schuh, Stephen
Sent: 18 March 2008 20:27
To: [email protected]
Subject: Severity of I/O interrupt records
I am using streamdevice to communicate with a VME crate
controller. One record sends a query string to the crate and
receives a string as a reply. The reply string contains a
lot of information and needs to be mapped to several records.
The records that receive this information are all
streamdevice records with I/O interrupt processing. This all works.
My problem is that I want the severity of all the I/O
interrupt records to be set to invalid if there is a problem
with the communication to the crate. The record that sends
the query string has invalid severity in this case. Can
anyone suggest a nice way to propagate that invalid severity
to all the I/O interrupt records? I thought about disabling
the records, but I think I would need to process the records
to make this work, and I don't know how to cause I/O
interrupt records to process. Is there an asyn option that
will cause I/O interrupt records to process after a
connection problem?
thank you,
Stephen
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- RE: Severity of I/O interrupt records Shepherd, EL (Emma)
Re: EPICS: Selecting a Text Error Message Emmanuel Mayssat
CALC expression feature request Benjamin Franksen
<2008>
2025
Re: Severity of I/O interrupt records Tim Mooney
<2008>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
