I have recently run into a problem when trying to get the CA client library (from EPICS relase 3.14.9) going on a VxWorks6.4 (mv5100) platform. I run through the normal sequence of creating a context, searching for the channel of interest, getting a value. This all works fine and I can sit in a loop for hours periodically printing out a value... Then I try to close things down. First I destroy the channel via 'ca_clear_channel'. This returns normal status. It's the subsequent call to 'ca_context_destroy' that has the problem. This results in the following message being printed on the console: "Unhandled C++ exception resulted in call to terminate"
1. I thought it might be something to do with the priority of the kernel task that runs the shell relative to that of the tasks that handle the network so I tried running my test function in a low priority task spawned from the shell. No improvement. 2. Initially I used the ca_disable_preemptive_callback threading model. I tried the preemptive threading model instead. No improvement. 3. I rebuilt the CA library with debug symbols enabled. I then fired up the Windriver workbench and delved into the call into the CA client code. Execution proceeded normally in the ca_context_destroy_code until the point marked "OUCH" ! void epicsShareAPI ca_context_destroy () { ca_client_context *pcac; if ( caClientContextId != NULL ) { pcac = (ca_client_context *) epicsThreadPrivateGet ( caClientContextId ); if ( pcac ) { delete pcac; // <---- OUCH !! epicsThreadPrivateSet ( caClientContextId, 0 ); } } } I followed the call into the ca_client_context destructor and did identify the line there that was causing the problem. But presumably the problem occurs due to my usage of the library or the way I have built it. 4. I have examined the options I used for building the library but nothing jumps out at me. I am attaching my test code together with the test journal. Many thanks for any suggesions - I am probably missing something obvious ! Simon Rees PSI Controls Group #include "cadef.h" #include <stdio.h> /* Note: the type of an EPICS motor .RVAL field is DBF_LONG */ #define MY_TEST_PV "PTEST-NCS-SC22:MOTOR.RVAL" void simon_ca_test() { chid myID; long value; int status; printf( "\n\nChannel access test function starting...\n\n"); /* Initialise the context */ printf( "Calling 'ca_context_create'... "); status = ca_context_create( ca_enable_preemptive_callback ); if ( status != ECA_NORMAL ) { printf( "\nERROR: call to 'ca_context_create' failed'\n\n" ); return; } printf( "ok.\n"); /* Buffer a create channel request */ printf( "Calling 'ca_create_channel'... "); status = ca_create_channel ( MY_TEST_PV, NULL, NULL, CA_PRIORITY_DEFAULT, &myID ); if ( status != ECA_NORMAL ) { printf( "\nERROR: call to 'ca_create_channel' failed'\n\n" ); return; } printf( "ok.\n"); /* Send create channel request to network*/ printf( "Calling 'ca_pend_io'... "); status = ca_pend_io( 5.0 ); if ( status != ECA_NORMAL ) { printf( "\nERROR: call to 'ca_pend_io' failed'\n\n" ); return; } printf( "ok.\n"); /* Buffer a get value request. */ printf( "Calling 'ca_get'... "); ca_get( DBR_LONG, myID, &value ); printf( "ok.\n"); /* Send get value request to network */ printf( "Calling 'ca_pend_io'... "); status = ca_pend_io( 5.0 ); if ( status != ECA_NORMAL ) { printf( "\nERROR: call to 'ca_pend_io' failed'\n\n" ); return; } printf( "ok.\n"); /* Display received value */ printf( "Returned value was: %d\n", value ); /* Clear down the channel */ printf( "Calling 'ca_clear_channel'... "); status = ca_clear_channel( myID ); if ( status != ECA_NORMAL ) { printf( "\nERROR: call to 'ca_clear_channel' failed'\n\n" ); return; } printf( "ok.\n"); /* Destroy the context */ printf( "Calling 'ca_context_destroy'... \n\n"); ca_context_destroy(); printf( "ok.\n\n"); /* Print test successful message */ printf( "Test completed ok.\n\n" ); } // simon_ca_test -> -> sp simon_ca_test Task spawned: id = 0x2523e20, name = t5 value = 38944288 = 0x2523e20 -> Channel access test function starting... Calling 'ca_context_create'... ok. Calling 'ca_create_channel'... ok. Calling 'ca_pend_io'... ok. Calling 'ca_get'... ok. Calling 'ca_pend_io'... ok. Returned value was: 1234 Calling 'ca_clear_channel'... ok. Calling 'ca_context_destroy'... 0x2523e20 (t5): Unhandled C++ exception resulted in call to terminate
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
