For what it is worth, I've attached an expect script that makes a listing of records for a given ioc. Brute force. Stop gap. Etc.Thanks for the script! You may also add that dbl > your boot server to your startup script. Add a cron job (or in the future trigger a script on the file server) to parse the dbl list and dump the channel names into you preferred name server. We are using LDAP for this purpose. The script is checking the date of the dbl file. If there's something new - go and update LDAP. This way we avoid bothering the IOC by user requests - ask the LDAP server instead. -Matthias
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
